S
smoothoperator
Guest
Since the battery test and firmware update are warranty work, and the brake fluid is extra, what do they do for the $600 service?
inspections, and change the wiper blades (extra charge)
.... This is almost like being told my differential fluid gets inspected regularly and needs changing every two years. .
Well if Roadster owners are seeing excessive moisture only in the rear brakes then something else is going on and you can't treat it like a normal brake system and ignore the fluid for years.PS. There is nothing different about an EV's brakes, except for lack of wear. You still can take your chances and go 20 years without maintence, or you can keep them in top shape by changing the fluid every two years. Synthetic brake fluid was supposed to be good for a lifetime fill, but never caught on for some reason.
...Ok, what's so weird about brake fluid to begin with? Isn't EVERY fluid nearly incompressible? So why is brake fluid so unstable?
That's a great question. Supposedly they re-torque all the bolts, clean the PEM and other air-cooled bits, make sure everything's happy, etc. I think it's a huge rip-off. It's hard to tell people that EV's are "so much simpler" mechanically yet I pay more in annual service fees on my Roadster than I have for any car in my life. I'll be interested to see what they're going to do for Model S.Since the battery test and firmware update are warranty work, and the brake fluid is extra, what do they do for the $600 service?
Synthetic and DOT 3/4 brake fluid is not exclusive. You can have both - the benefits of synthetic DOT4 fluid is high resistance to overheating and resulting brake fade.While synthetics have been available for decades, the older DOT4 fluids still dominate the market. I thought synthetics would take it over, like radial tires and fuel injection.
Correct, DOT5 is track-use only (or if you don't have a life and want to bleed your brakes every month). As for OEMs not using synthetic, it's the same as oil - cost. Synthetic oils have been around for ages but OEMs have just recently started using them. Get a good synthetic DOT4, bleed it biennially, and enjoy.Synthetic and DOT 3/4 brake fluid is not exclusive. You can have both - the benefits of synthetic DOT4 fluid is high resistance to overheating and resulting brake fade.
You are probably thinking of DOT5 brake fluid. DOT5 brake fluid is silicone based and does NOT absorb water. But don't go thinking that this solves the brake change interval problem.
Because DOT5 does not absorb fluid, instead what happens is that the water that gets in forms bubbles in the system, creating localized areas where high rates of corrosion can occur - or if this water is close to the brake calipers, very easily boiled fluid.
So if anything, regular flushes of DOT5 fluid is even more important than DOT4.
