Hi all,
I want to purchase a foam cannon and air compressor online that are compatible with each other and produce the best foam car wash experience possible, i.e., foam application, thickness, adhesion to the vehicle, etc.
Can anyone post product names or Amazon links to this combination of equipment you may be using? I researched the issue but its more complicated than I thought. I assume I would want an electric compressor that "mates" properly to the "foam cannon" to produce the best experience. Some are saying to get a gas compressor but I have a Model X. This seems counter-intuitive. If I need any additional hardware to mate the equipment, I'll need to know that as well. Some of these cannon / compressor combinations, as my research is uncovering, is not ideal due to required adapter tips on the compressor that will not work ideally with a foam cannon.
Also, what is the best foam product to purchase to go along with this to produce the best results?
Thanks in advance!
Thanks in advance!
