Fob not detected while driving
Discussion in 'Model X' started by jnt76, Aug 12, 2016.
Tags:
  1. jnt76
    jnt76 Member
    Westchester NY
    Has anyone got this message on the dashboard? I was driving yesterday and noticed the error message. I noticed that my fob was on top of my iPhone while it was on. Perhaps the phone is jamming the signal coming out of the fob? I tried to replicate the situation but it didn't happen again. Maybe the phone was connected to wi-fi the first time around.
  2. ronsbell
    ronsbell Member
    SF Bay Area
    I had this happen once in the Model S, even to the point where the car warned me to pull over and then shut itself down. Swapping out a low battery in the fob fixed my issue.
  3. jnt76
    jnt76 Member
    Westchester NY
    Thanks! Considering that it's only been two months since I got the car. I'll contact my SC or is it something I can do myself?
  4. madodel
    madodel X at the end of a rainbow
    Poconos, NE Pennsylvania, United States
    I keep a spare battery (CR2354) in my X in case. It is not complicated to change the battery and there should have been a pry tool in the box that the FOBs came in. But if your Tesla is only 2 months old and it isn't a pain to go to your Service Center then they should change the battery for you. How fast the existing battery depletes depends on how often it is within range of the Tesla. When I spend time in my garage my X is constantly sensing the FOB and waking up and then shutting down again. I have a FOB pouch that blocks the signal, but I usually forget to use it.
  5. X Fan
    X Fan Supporting Member
    Naples, FL & OIB, NC
    early May delivery & had same issue in early July......SC fixed about a month ago with a firmware update (needed to give them both key fobs) & new battery in each.
    You may need both.....
  6. wilheldp
    wilheldp Member
    Louisville, KY
    I have also been having this problem intermittently with my Model S. It is only 3 weeks old, and I have had it give me the dashboard message 3 times so far. It also extends the door handles at different distances (sometimes they extend when I'm 5 feet away, sometimes I actually have to double-click the fob to get them to extend).
    Do you know what firmware version fixed that?
  7. X Fan
    Sorry, don't but will check back with my SC and advise..
  8. ronsbell
    ronsbell Member
    SF Bay Area
    Hi, I've attached the page of the Model S manual that explains how to change the CR2032 battery. The same page also says that phones and other radio devices can interfere with the fob signal from time to time.
  9. Akikiki
    Akikiki A'-Lo-HA ! y'all
    Kaneohe
    Any cell phone signal located near the fob will block the fob signal. Don't even carry the fob and cell phone in the same pocket or purse.
