Fogging windows
Discussion in 'Midwest/Great Lakes' started by kevincwelch, Dec 25, 2012.
  1. kevincwelch
    kevincwelch Active Member
    Chicagoland
    Any feedback from Midwest drivers about this window fogging issue that is being tossed around in the S forum?
    Sent via Tapatalk.
  2. goaliemanshark
    I'm in the bay area and I have had a lot of fogging problems.
    Cleaning the interior windows with windex helped A LOT! The interior materials offgas for a while and get crap on the interior or the car. Causing fogging.
    Windex and some Rain-X anti fog solved everything.
  3. Zextraterrestrial
    Humboldt/Los Altos
    My tint doesn't seem to fog as of yet. the front window condensed water on the inside. I windex/ rainx anti fogged the inside of the front and instead of fog it gets beads of moisture.
  4. FlasherZ
    As much as the materials are off-gassing, I've been trying to keep it clean but it's not always that easy.
    I've found that I can maintain a good interior by using the "range driving" setting ("eco" climate control). I set auto fan, but manually set outside-air, compressor on, and floor + windshield. That seems to maintain a good cabin air quality for me.
  5. DrComputer
    DrComputer Active Member
    Sherman Oaks, CA
    I just drove home tonight with 4 passengers in the car and the front and read windows kept fogging up (the outside temperature said it was 46 degrees). If I turned on the front defroster it would defog the windows for a few minutes. I then noticed that when the climate control system is on Auto and the car is using heat the A/C is turned off. In most automatic climate control cars the AC will remain on with the heat to reduce the humidity in the car. I think Tesla needs to tweak their Auto algorithms and cycle the AC when the heat is on to reduce fogging. This is a simple software fix.
  6. kevincwelch
    Chicagoland
    Really disappointing. This needs to be fixed; it seems like a design flaw.
    Sent via Tapatalk.
  7. William13
    William13 Active Member
    South Bend
    I have not had any fogging issues. I use the defrost as needed, occasional. I expect the reports are from either plugged defrosters and/or not cleaning the inside of the window. I have had four adults in the car for hundreds of cold miles.
  8. strider
    strider Active Member
    NE Oklahoma
    +1. And you need to clean the windows once a week or so until all the "new car smell" goes away.
