Foglights Question (post model changes)
Discussion in 'Model S' started by thegruf, Apr 10, 2015.
Tags:
  1. thegruf
    thegruf Active Member
    indeterminate
    The Premium pack gets you LED Fog and cornering lights (I assume the same lamp).
    Without Premium pack do you get:
    No foglights at all?
    or
    non-LED foglights?
  2. jerry33
    Texas
    No fog lights as far as I know, but as fog lights are 95% useless because they are always paired with the low beams (due to regulations), it's not a big deal.
  3. Tree95
    Tree95 Member
    Usa
    Fog lights and cornering lights are different bulbs. The fog lights are much brighter and face mostly forward. Each cornering light points about 45 degrees out from the car.
  4. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Without the Premium Package option the car will not have any fog or cornering lights, which are two very different lights.
  5. Law&Disorder
    Law&Disorder Member
    Long Island, NY
    Did the old Tech Package include the fog lights or just LED cornering lights?
  6. neroden
    neroden Model S Owner and Frustrated Tesla Fan
    Ithaca, NY, USA
    It seems that many people here have never driven with fog lights in fog. The new fog lights work (the first generation fog lights did not work), and if you drive in a lot of fog, you want them. I actually paid for the retrofit because we get some serious fog out here.
    (Hint: if you're driving faster than about 10 mph, you do not need or want fog lights. They are for *serious* fog.)
    You get no fog lights at all unless you order the package which contains them.
  7. SW2Fiddler
    SW2Fiddler We Are Cognitive Dissidents
    Houston TX
    The fog lights are very useful for spotting potholes in dark streets.
  8. mknox
    mknox Well-Known Member
    Toronto, ON
    That's new. The non-Tech cars used to get just the cornering lights.
  9. rnguy001
    rnguy001 Member
    Bethesda, MD
    I was quoted by my Tesla Rep that retrofitting Fog Lights was around 2k, he had just called the service center to inquire..
  10. marchyman
    marchyman Member
    San Mateo, Ca
    Both came with the tech package when my car was delivered in Dec. Or at least my car has both... I guess I can't say for sure that one or the other options weren't standard.
  11. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    I mean, that should be obvious, right? You don't want your high beams on in the fog. High beams are essentially the exact opposite of what you want when it's foggy. Same thing applies when driving in the snow.
    Depends what you mean by "old Tech." The fog lights have been revised and moved around quite a bit. Depending on the car's age, they may have been standard, a separate $500 option, or included in the Tech package. Example: I have cornering lights, but no fog lights because I didn't select that $500 option.
