Folding Mirrors problems
Discussion in 'Canada' started by RAM_Eh, Jan 23, 2014.
Tags:
  1. RAM_Eh
    RAM_Eh Member
    Toronto ON
    Anyone having problems with the mirrors folding back out to the correct spot?
    Since delivery mostly the passenger side, but both mirrors will not fold back out the max. Definitely is worse below freezing but a few days above 0 deg C I still have the problem...so it is not the temperature all the time.
  2. Kalud
    Kalud Active Member
    Montreal, QC
    I've had the passenger side that didn't unfold once. After one month I decided it wasn't worth it to leave it on auto fold/unfold as most of the time folding is not useful and over time its wear on those motors. Also ice and snow can be a problem. I press the fold button when I want them folded (in parking lot mostly) and once they were both jammed in ice and didn't move.
    Oh strange note, you can actually fold them at any speed, that's weird. My former bmw did auto unfold at about 20km/h and refuse to fold above that speed (for safety concerns I guess...)
    - - - Updated - - -
    Maybe check for dirt or salt accumulation in the moving parts, the motor is not that powerful and abort easily.
  3. CanuckS#69
    CanuckS#69 Member
    Sutton West, ON
    When do they fold/unfold on the auto setting? I've wondered whether they'd be useful or just annoying for parking in a tight home garage.
  4. Kalud
    Kalud Active Member
    Montreal, QC
    I find the AUTO setting annoying, every time you leave the car they fold, then you forget something, you return: they unfold, then you leave: fold. I guess that a better setting would be auto-fold on lock, then unfold when the car is moving (or at a defined speed)...
    But fortunately there is a setting to disable the AUTO function and a button to manually fold/unfold when really needed.
  5. RAM_Eh
    RAM_Eh Member
    Toronto ON
    I like the auto fold option, just need it to work properly.
  6. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I had a loaner with auto-folding for a couple of days. The Auto function is useless. I would leave them on manual at all times - the button is conveniently located on the window control panel, between the two buttons for outside mirror adjustment.
  7. ThosEM
    ThosEM Space Weatherman
    Annapolis, MD
    I've had the same problem. Usually I notice before or after starting out that one of the mirrors has not deployed. Cycling the car off and on again has always resulted in a proper deployment, so I'd been attributing the problem to logic confusion as we walk past the car and it unlocks and then locks again. But temperature could be a factor, I suppose. I reported it to the SC, with specific date/times so they could look at the logs in the system. So far they haven't commented but this has only been a minor annoyance, so haven't pressed it.
    I hadn't noticed that there is a way to turn off the automatic deployment, and may deactivate that, as an interesting experiment if nothing else.
  8. mcfadyena
    mcfadyena Member
    Campbellford, Ontario
    I had a loaner today and for the next few days. When I got in, the passenger mirror didn't unfold. I was afraid I broke it somehow. After hitting the fold in/out button on the door, it jumped out.
  9. cwave1
    cwave1 Member
    Mississauga, ON, CANADA
    Mine are on auto and I have problems all the time. Sometimes I even get a partial unfold. A quick press of the button twice (once to partial fold and once to unfold) seems to re-sync them.
  10. RAM_Eh
    RAM_Eh Member
    Toronto ON
    That does work actually.
    I have third appointment tomorrow for a new mirror firm ware update.
  11. ThosEM
    Annapolis, MD
    Turning off the automatic function is a nice way to reduce the number of cycles when walking around one's car in the garage. The SC in Rockville reached out to tell us a fix for the automatic deployment confusion is in the works, and now I see that it arrived in the software update that just arrived last night. So I guess I'll turn it back on and see how things go. We have activated our mirrors manually in icy weather, in a car wash, and elsewhere, without a hitch, so it seems likely this was a software logic glitch and not a mechanical problem.
  12. RAM_Eh
    RAM_Eh Member
    Toronto ON
    Since the last firmware upgrade they appear to work properly. Colder weather coming in the next few days. Will report back?
  13. markn455
    markn455 Member
    Ball Ground, GA
    I have started having regular problems with the driver side mirror only opening part way. This is very annoying. It happened months ago and then started getting stuck every couple of weeks. No it happens every few days and sometimes multiple times per day... Getting frustating.
  14. Peter_M
    Peter_M Member
    Ottawa, Canada
    It seems to be caused by dirt in the mechanism. My mirrors get sticky every winter and they are fine in summer or whenever I get the Tesla service folks to clean and lubricate them.
    Whenever they get stuck, press the button twice quickly to extend or fold them the rest of the way.
  15. markn455
    markn455 Member
    Ball Ground, GA
    Went to service center today. They checked the mirrors and found the driver side mirror to be defective and replaced. No charge!
  16. SUN-day Driver
    I have seen an occasional case of one or the other only partially unfolding.
    I too think the auto mirror folding is useless. I want them to fold before I start pulling into the garage and stay folded until I've pulled out of the garage to clear the door frame. Of course that's not how it works so I have auto folding off and I use the button to fold and unfold as needed.
  17. Peter_M
    Peter_M Member
    Ottawa, Canada
    I sent Tesla a request for a feature where the mirrors would fold/unfold whenever the car sends an automatic location-based garage door open/close signal. It would be an option per Homelink door. The existing auto fold option would stay but not apply within the geofence area of a door that has autofold enabled. That way, the mirrors would fold when opening the garage, unfold when closing it, and fold/unfold when parking elsewhere.
  18. wayner
    wayner Active Member
    Toronto
    A bit OT but I saw a story where Japan was the first country to approve getting rid of side mirrors (they will be replaced with cameras). I bet that this will happen ASAP with Tesla as it will really help with aerodynamics.
  19. TooManyAirMiles
    Canada
    I had a folding problem too but it is unpredictable and not repeatable. When I went for annual check up they said it was fine… and it was… until a week later. Now it is fine again.
    My understanding is that Tesla DID design the S with no side mirrors so that it was more "slippery" but it could not be approved by government regulations at that time so they had to add them back into the design.
  20. wayner
    Toronto
    Apparently Japan has now approved the use of cameras in lieu of side mirrors. Hopefully other countries get on board soon so that we can further improve aerodynamics.
