For Those With "Clicking" Sounds While Turning
Discussion in 'Model S: Driving Dynamics' started by theslimshadyist, Feb 7, 2017.
  1. theslimshadyist
    theslimshadyist NashVegas!
    Franklin, TN
    Hey guys,
    I just wanted to share this as an FYI. My MS was experiencing clicking sounds up front primarily when turning the steering wheel to the left. However, the issue was resolved and below are the notes from the tech.
    "Test drove vehicle and verified customer complaint. Found noise coming from front sub frame skid plate. Modified skid plate and test drove vehicle, customer complaint was corrected".
  2. brianman
    brianman Burrito Founder
    Another data point...
    I had a similar popping/clicking and it was a suspension issue. I don't have the paperwork handy right now or I'd post more details.
  3. LittoDevil
    LittoDevil Member
    San Francisco, CA
    The noise is actually coming from the steering rack to the front sub frame.. that's the specific answer. They fix it by adding a shim to the steering rack mounting points, it's a technical service bulletin and a known issue. The newer Model S has a totally redesigned steering rack that's designed in house. I forgot which vehicle the original steering rack is from but it's from another vehicle.. i want to say range rover but I can't remember. I had the same issue as well and I'm very close to the techs and engineers at Tesla and was inquiring about that hehe.
    -Larry
  4. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I had a faint clicking sound, and it turned out to be a wiring harness rubbing on the steering column.
  5. LittoDevil
    LittoDevil Member
    San Francisco, CA
    Oh thats bad.. imagine if the wiring harness got rubbed or chewed thru!.. the clicking sound I had was much more prominent.. like.. really loud and you can actually feel it in the car.. lol
    -Larry
  6. Doug_G
    Ottawa, Canada
    Well it was easily fixed, and I was relieved that it wasn't the start of something that could get progressively worse.
  7. theslimshadyist
    Franklin, TN
    Good to know that your info aligned with what the tech diagnosed with my car, it makes me feel better that this is a known issue and not a "one off".
  8. SarahsDad
    SarahsDad Member
    NC
    Ahh, glad I found this thread. Have noticed increasingly frequent but somewhat random clicking sounds, almost knocking, coming from R front of car, usually when first starting to drive, when hitting minor bumps or turning left. Sounds like the OP's problem. Will check with service tomorrow.
  9. Gig103
    Gig103 Member
    Phoenix Metro Area
    Good to know. I had them test drive mine a while back and was told it was "In spec". Any chance someone has the TSB number so I can call and be ready for them?
    Data point - P85D.
  10. Ahisaac
    Ahisaac Member
    Leesburg, VA
    I'm experiencing the same issue. I took it in on Thursday last week and have an Appt for this Tuesday. I'll have more details once the work is underway / completed.
  11. Brian-MS90D
    Brian-MS90D Member
    Cincinnati, OH
    MS developed this symptom just last week. Made an appointment at SC for today. SC replaced front skidplate today under warranty (according to service ticket). Problem solved.
