forum confusion
Discussion in 'Site Feedback' started by sp4rk, Mar 4, 2013.
  1. sp4rk
    sp4rk Banned
    Schaumburg, IL
    Are you aware this is by design?
    The red button you press to lower it? You can also press this button in for 3 seconds to make that height the new maximum height. You probably pressed it.
    Manually lift the gate to your desired height, then press it again for 3 seconds until it beeps and it should work as before.
  2. Al Sherman
    Al Sherman It's about THIS car.
    Batesville, IN
    The Roadster HAS this feature?
  3. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    The Roadster doesn't have this feature, just the Model S.
  4. sp4rk
    sp4rk Banned
    Schaumburg, IL
    Rats! Did it again ... there needs to be some clearer indication that it's the Roadster subforum, not Model S.
    Mods, if you delete my reply, I would be grateful!
  5. jordanthompson
    jordanthompson 2018 P100D Model X
    Satellite Beach, FL
    Are you aware this is the Roadster Thread? The Roadster does not not have this feature - its basically up or down :)
    - - - Updated - - -
    Not to rub (too much) salt into the wound, but its pretty obvious to me :)
    Of course, I've done it myself also.
  6. dsm363
    Nevada
    It's no big deal. Think it's more likely to happen if you use the 'what's new' list instead of browsing forums one at a time.
  7. sp4rk
    sp4rk Banned
    Schaumburg, IL
    I always use "What's New. So that explains it.
  8. doug
    doug Administrator / Head Moderator
    SF Bay Area
    <Ahem!>
    What's New:
  9. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Maybe you could swap the colums so the forum is right next to the topic?
  10. sp4rk
    sp4rk Banned
    Schaumburg, IL
    Ahemmmmm. To you too. :)
    You sound like Achmed, the Dead Terrorist. (See Jeff Dunham - Achmed the Dead Terrorist - YouTube ) 1:30 in
    (Clearing his throat)
    Yes that screen does show the sub forum but I (like others maybe) never look all the way right, just the highlighted left column?
  11. brianman
    brianman Burrito Founder
    @doug/Doug_G - If you really want to "nail it" (solve the problem), add something like the "W3C Recommendation" banner [http://www.w3.org/TR/CSS2/] to the threads/posts (not the list but the actual posts) but put the sub-forum name in the banner.
    I can try to cobble something together if you want a sample.
