Found front mud flaps that will fit without trimming on the MY. Very inexpensive on Amazon - https://www.amazon.com/gp/product/B07T545SDS/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
They are flexible enough that if you firmly press them into place, they contour to the body nicely without trimming and look 'factory'. Only downside is that you need to drill all new holes in the plastic wheel arch trim to mount them. None of the factory holes line up. Going to install tomorrow, but install looks simple enough - press firmly into place, mark holes, drill, then mount. I may actually place in boiling water to loosen them up more and press into place to stretch them out a bit for an easier fit, but these are WAY closer fit vs. the M3 mud flaps. Will look about as factory as we are going to get for now.
As for rear mud flaps, I only see custom-designed as a solution for the MY, since the wheel arch is really curved at the rear, creating a difficult mounting surface. I purchased a 6" wide roll of Xpel to cover the rear bumper area above the black plastic as my safeguard against road rash from the rear tires.
