Looks elegant and flows along with the screen. This one is strong enough that it does not wobble. Only problem is that steering wheel covers it a bit.
Amazon
Amazon
That looks neatLooks elegant and flows along with the screen. This one is strong enough that it does not wobble. Only problem is that steering wheel covers it a bit.
Amazon
One of my biggest gripes about having to wait on my M3 invitation and then delivery is that I can’t design and print my own accessories specially designed for the M3. A phone mount is something I’m looking forward to doing.
Why is a phone mount necessary on the Model 3? I know the phone plugs in down in the cubby area but why do you need it by the screen? I assume you use the screen for Navigation right? If you're going to use something such as Apple Music, is this why you want your phone viewable?
I've thought about getting into 3D printing, but lack any place in the house to set up something that really stinks (so I've been told).
In my opinion, for a car, PETG is the way to go -- higher melting temperature and no smell while printing. Just make sure to keep the filament dry. I use this system to keep the filament loaded on my printer from absorbing air moisture: Airtight Filament delivery system (almost) by stephenmhall
Amazon
This is really helpful... thank you, guys! I’ve been pondering how to mount the phone in the same area to keep my phone within forward line of sight. Question about attachment: does the mount attach to the back of the tablet via suction or adhesive?I ended up getting a slightly different model but pretty much the same form factor. Thanks for the lead, OP.
https://smile.amazon.com/gp/product/B0721B4TW4/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1
Have you worked out a charging solution while using this mount? I've been thinking about this very thing for a long time and that's the long pole in the tent.Looks elegant and flows along with the screen. This one is strong enough that it does not wobble. Only problem is that steering wheel covers it a bit.
Amazon
The one I got is semi-adhesive gel. It's sticky to the touch but it's not a permanent stick. You can peel it off. The reason I didn't go with the original model that the OP suggested was that I couldn't confirm in any product description whether the base was suction or adhesive.
This. I’ve been searching for a magnetic qi charger that will mount with a suction mount, and articulate enough to allow it to attach to the back of the screen, but so far, no luck. Plus, none of the magnetic chargers seem to allow full rotation (landscape). May be a limitation of qi charging, since there are plenty of magnetic holders that allow rotation.Have you worked out a charging solution while using this mount? I've been thinking about this very thing for a long time and that's the long pole in the tent.
