would that 0.25m cord reach the Tesla USB port and still allow the tray full movement?
there is no way it would reach the port
After 2 bad purchases, I've finally found cables that fit:
https://www.amazon.co.uk/gp/product/B074QLJQS6/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
View attachment 461439 View attachment 461438 View attachment 461437
I assume you connect your 4 port hub to the 12v supply rather than the USB? If you use a higher power adapter does it maintain the higher currents for fast charging? I'm using another 4 port hub which I don't think does.
Thought so, thanks.
So, my guess is that 0.3m - 0.4m is the minimum length required.
Or if really fussy you can buy a battery bank instead of a HUB, so the bank is constantly charged and then fast chargers the phones when they are plugged in.... The car slow charges the bank while parked etc. I might just do that actually...
https://www.amazon.co.uk/Anker-Powe...ywords=USB+battery+bank&qid=1569952894&sr=8-6
I think the usb sockets go to sleep if the car does. Only on if you keep Sentry mode on. It does with my Raspberry Pi zero.No, the 12v socket is in a different compartment so no way of doing that. As for quick charge, I don't notice any difference. The HUB is USB3 and sockets are USB2 so no fast charging anyway... Hub can handle way more than the socket delivers, so if one phone is plugged in it will charge just as fast. Don't know what happens if 2 are plugged in though.
Can always just plug the second cable direct and plug the little one and the SSD into the HUB if charging is slow.
I think the power packs can not do both (charge and discharge) but there maybe one that can. Not seen one that can yet.Yeah, but you don't need to rapid charge all the time. I think the power bank would ultimately be topped off.
Only thing I'm not sure about is if the bank can charge and discharge at the same time. If it can, then the worst case is that it will just pass through the charge.
And of course if the car is charging it's not sleeping.
Would it affect the range if the power pack is kept charging all the time?
how many days needed to arrive? I heard that most products on aliexpress need about a month to arrive or morem using one of those, Magnetic. No need to find connector to plug it in. Strong, works 100%. : US $2.94 28% OFF|고속 90도 팔꿈치 3in1/IOS/마이크로 USB/USB C 자기 충전 케이블 삼성 Note 8 S9 S8 S7 S6 아이폰 x 8 7 6 플러스-에서휴대폰 충전기부터 전화기 & 통신 의 Aliexpress.com | Alibaba 그룹
