frequency of charging using SC
Discussion in 'Model S' started by mrtian97, May 24, 2017.
Tags:
  1. mrtian97
    mrtian97 Member
    So Cal
    to preserve my battery life, what's the suggested frequency of using SC vs charge at home? I was told by one of Tesla OA that I should not charge too often with the SC to avoid deterioration of my battery. My Tesla will be new S75 (taking delivery next month).
    I am thinking to use SC couple times a month
    Thanks
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    Charge at home for normal use and then use the Supercharger when you need to use it.
    • Like x 5
  3. googleiscoul
    googleiscoul 3 months maybe, 6 months definitely......
    Aldie VA
    A few times a month doesn't sound that bad - also the degradation is heavily effected by ambient temperature be sure to put that into account as well. Because when the battery hits a certain thermal limit it is degrading faster than usual. Be sure not to charge to %100 to often either it is worse or the same as Supercharging too often (IMO).
  4. Viking1
    Viking1 Member
    I think the jury is still out. In a survey conducted online (self reporting) it appeared the best result for low battery degradation was to SC daily. However, the number of people doing that was few, so the results are suspect. One theory I read is that charging at say 10kW on the UMC kept the battery warmer longer then SC, which resulted in more degradation using the UMC/Level 2.
