Gonna go with manufacturing defect, air void or contamination in the rubber when the tire was made. Held together barely, then the chunk detached.I had 10+ years no flat in my pre-Tesla car. Then I got a Tesla and suddenly the other car had two flats and then I got another Tesla (lemon the first one) and withint 1.5 months had two flats... Things just happen I guess.
the first one was (a very gentle) bump against curb that completely ripped out a section in sidewall that immediately killed the tire, TPMS gave me warning of flat withing 10 seconds of the event.
The second one is a mystery. The tire is melted and the cord is exposed and I am not sure what caused it, but it was a relatively slow leak so I was able to pump it up and go to a tire shop all by myself. The first warning appeared pretty soon after the event it appears too.
By punctures, I mean debris in the tires. It has been glass and nails. I have the 20's bc I thought I would have fewer issues with this size. Previous vehicle was a Yukon and the tires were much bigger
All on the left so far...
i weigh 420lbs. and report the same wh/mi as all users here. in fact my wh/mi with 4 people or 7 people sees almost no change.Yea sorry I caught that! A spare tire, plus a jack, plus all the tools and supplies weighs close to 100lbs. 100lbs, of what should be unnecessary equipment will have an impact on range. I don't care how minimal it is, the fact of the matter is, the more weight you add to these vehicles, the worse the range.
Mate, I've had the exact same issue. Bought my model 3 a year ago. Within the space of 11 months, I've had to change 3 tires. All 3 have had a nail in them. I'm beginning to wonder whether the tesla only 'Acoustic' tires (mine are the michelin run flats) are softer / more prone to getting punctures from debris or nails. It's costing me a fortune.I am having very frequent tire punctures and tire issues in general. It has gotten to the point that it is really ruining the experience of owning this vehicle. I have had 4 tire punctures since April. I am averaging a tire puncture about every 6 weeks. My wife and I can't remember the last time we had a tire puncture or issue. We can't think of a single tire problem between the two of us in the last 15 years. Nothing has changed about the way we drive or where we drive, the only thing that changed was the vehicle, which makes it feel like it is a problem specific to the Model X or the tires.
To add to the stress of this, the TPMS sensors don't tell us the pressure in the tires until we are a mile or two down the road. So by the time we get the low pressure signal we are well on our way to work or to drop kids off at school, at which point we have to turn around and go back home to the compressor. As a result, I have to go out and manually check the tire pressure, every time we want to drive, which makes driving this car feel more like a chore than something I enjoy. My daughter and wife have been significantly late for school and work twice now bc of this issue.
Another issue is that we no longer feel confident traveling long distances in this vehicle without having some tire troubles. As a result, I have purchased the Tesla spare in a can, a full sized spare, and a full tire changing kit. This adds quite a bit of weight to the vehicle, taking up precious cargo space and depleting the battery more quickly due to the added weight.
This is getting really frustrating and it makes this car no longer enjoyable or dependable for us. We wanted the larger wheels but opted for the smaller ones bc we didn't want headaches with the tires. Well we are still having headaches with the tires. What do we do? Is anyone else dealing with this? Is this normal?
I know it's most likely down to misfortune, but seriously beginning to wonder whether the foamy acoustic tires are worth it or not?
I had 6 flats over 4-5 months. I thought it was chance, but this has me thinking. All were in the oem contisilents. I had the nonfoam version and they never had a flat.
On another note, the inside wear is crazy! I go through tires way faster than any car. Alignment helped, but I've never got 20k on a set. Ready for my 4th set now and I have a 2020!
Yeah, I've been following that one, along with the shudder and other alignment threads. Wish that it could be set at 0 so it didn't get drug sideways. I wear way too fast on this car.If you want to know why your tires wear faster:
Breaking down the excessive rear, inner tire wear
I had a bunch of warranty work done at the dealer, some of which included replacement parts for the shudder. The entire front end of the car was apart. After I picked the car up I noticed that it was pulling right and immediately suspected an improper alignment (or, in this case...no alignment)...teslamotorsclub.com
OEM is adjustable, but the range is limited.OK, so I get the aftermarket camber arm thing since the stock ones are totally non adjustable , but the stock *toe* arms *are* adjustable on the model X. They use eccentric bolts, maybe not as precise as an adjustment as one might like, but a person who has time equipment and experience can get it to within a fraction of a degree, is this not true? Why do you *need* to replace them?
