When you change the cabin filter in cars they are usually full of leaves, bugs, and all kinds of particles. Looking at the intake under the frunk I thought it would be easy and cheap to add some pre-filtration there. Went to the hardware store and purchased a sheet of "cut to size" universal furnace filter material. This will prevent the bigger stuff from getting into the system and substantially prolong the OEM filter. Cost was $15 and I was able to cut 3 out so about $5 a piece.
Cut the piece out just a little larger so it kinda squeezes in place. The structure of the material against the foam surround is almost like velcro and holds in place really well.
Though some of you would be interested in this simple, inexpensive addition.
By the way, there are special intake filters similar to this for the model 3 however they are much too restrictive and cause issues, this works so much better and is dirt cheap in comparison.
Click on the photo for a larger view.
This put in a couple of weeks ago, already crap on there and although hard to see it is starting to blacken. Going to dty to hose wash one with some degreaser when it gets bad enough as they may be reusable a few times. Good part is you get a good visual on how dirty it is every time you open the frunk.
