Front camera usb showing an x symbol
amoeba
43
57
Fremont
I plugged in a 8GB USB stick into the front USB slot with the pre-created folder. The car detected the USB and brought up the front camera usb recording symbol. After a day though I noticed that it's now greyed out and showing an 'x' on the upper right corner of the symbol. Anyone else run into this?
zacyee
72
30
San Diego, CA
Common issue. The drive has become corrupted. Plug it into your computer and repair the drive, it may re-occur in the future.
Seems to stem from the software not suspending the drive when going to sleep, but the true cause has been unconfirmed.
alchymia
18
17
Small sample size of a few days, but since I've been on 2018.40.1 I've had no issues where it used to happen almost daily. Hoping it keeps up.
PoitNarf
My dog's breath smells like dog food
Jun 7, 2016
2,860
3,994
NJ
Can you elaborate on this? Turn off camera with 2 second push on what?
The camera icon on the touch screen. If you press and hold the icon it will stop recording. Press and hold again to resume recording. A quick tap on the icon will save the last 10 minutes of video to files that will not be overwritten.
Bigjohn892
53
25
Chattanooga TN
I had the same problem and service said the update should fix it. I received update 42.3 and now the camera doesn't show on the screen??? Has anyone else lost the camera completely
StellarRat
1,490
1,337
Pacific
I haven't tried reformat
I think you'll have repair/reformat the USB stick before turning off the camera is going to help you. Once mine was corrupt it never worked again until I did the reformat (FAT32).
I haven't reformatted the camera partition since the update to 42.2 . I gave on on the camera after the third reformat. I guess I should do that and see if the problem is gone for good.
Bigjohn892
53
25
Chattanooga TN
I re-formatted the disc and inserted but still no camera icon on the screen.
I had everything working with the camera after version 9 came through then two weeks later when I got in the car the screen message said it was trying to install version 9. I had to drive to an appointment so I X'ed out since version 9 was already installed and drove. Some time after that the camera icon just showed an X. Now the icon is cone entirely???
