Also there are two settings for defrost. Push it twice for full power. Turns the car into a sauna if you leave it on, though.
Clearly, the defrost settings still need some tweaking. I'm not clear on why Tesla turns the temp up to high. Every other car I've owned will a) turn on the a/c compressor if the temperature is above about 40 degrees F and b) turn the fan speed to high. The temperature is typically not adjusted from wherever the user has it set.
The way it is now, I would have to use the first Defrost setting, then manually turn the fan speed up.
Anybody else have an issue with slow defrosting on the front windshield?
Not available yet last I asked.Have the service center install the winter package.
Yep, had this happen the other day. A warm and very muggy (85%+ humidity) day. With the AC on, the fog condenses outside on the windshield (probably due to some cold AC air leaking out the defrost vents, cooling the bottom of the windshield).I actually notice 4 distinct "foggy" patches on the lower part of the windshield OUTSIDE the car. They clear as I drive, but the defroster does not help this. We are having 90+ degree weather here; it's an odd phenomenon I've had happen 3 times. Anyone else?
The Vancouver service center just got the vent upgrade kit parts delivered yesterday afternoon. Perhaps other centers will get it soon too. Had mine installed while i was there, but haven't had a chance to test it out yet.
