took delivery today , and i dont like the lic plate holder they said its glued on the front bumper, anybody had an experience taking them off ? if so did it damage the paint underneath the glue area and HOW? .thnxs in advance...
What don't you like about it? It sticks on and holds your front plate. I've had mine since September 2018 without issue.took delivery today , and i dont like the lic plate holder they said its glued on the front bumper, anybody had an experience taking them off ? if so did it damage the paint underneath the glue area and HOW? .thnxs in advance...
I recall seeing in a Model 3 owner’s manual - available online somewhere - how to attach the front number plate holder, with photos. It has strips of 3M double sided tape with the red film. Therefore it is strong (red tape is stronger than green tape) but it is removable. You can use brake cleaner to soften the adhesive before pulling the holder off, or you could use fishing line in a kind of cheese-wire fashion (apparently dental floss works as well) to cut through the foam tape, then clean off the residue later with the brake cleaner.
-Alex
Warming (i.e. softening the adhesive) is the key. I haven't yet removed a Model 3 front plate holder, but I helped remove the base of the Model S holder, which uses the same kind of tape. Carefully pulling it off while aiming a heat gun on the gap with the adhesive made it rather easy.This is exactly how it is attached. It is not easy to remove. Dental floss will get you started from the top corners. If you are lucky, it will have been installed poorly and the double-sided tape will have not made full contact with the bumper. In my case, it was attached at the top and bottom with the middle section floating free. Warming the area will help so I suggest parking the car in the sun before attempting to remove. There was no damage to the paint but be careful with the dental floss!
This is always a confusing subject for me - it’s hard to imagine how it would be ‘optional’ to have a front numberplate. What happens with speed cameras and toll gantries if you don’t have a front plate? Heavy fines here
took delivery today, and i don't like the lic plate holder they said its glued on the front bumper,
if so did it damage the paint underneath the glue area and HOW? .thanks in advance...
Did you get yours from Costa Mesa? I tried telling those putz' not to install mine and they ignored me and installed it. They did tell me they use 2-sided tape which should come off easy.took delivery today , and i dont like the lic plate holder they said its glued on the front bumper, anybody had an experience taking them off ? if so did it damage the paint underneath the glue area and HOW? .thnxs in advance...
