Fair Verona
I'm going to give this one a shot. For 8 bucks I've not got much to lose.No, I was able to install it 5 mins and remove in a minute.
Inexpensive option,
No-Hole Tesla Model 3 Front License Plate Installation kit | eBay
works great for me.
It is a small surface area and the fins (louvers) are fully exposed. So I don't see this as a problem.Are we not concerned about the blocking of airflow into the air damns to help cool the battery?
Bad idea.Did anybody consider putting protective layer of scotch tape on the bumper before using VHB tape? Bad idea or not?
Found a front plate holder that does not block the sensors. Make sure you get the 2" extension arm. It is well made and can be removed when showing the car. It uses the tow eye for mounting.
https://www.cravenspeed.com/the-platypus-license-plate-mount-1/View attachment 287878
This revision seems to fit alot better. A few minor adjustments to do..
The Bandit is CNC routed from HDPE Marine Board. It's available for ordering here (approximately 4 weeks out). ThanksHi Tony, This is definitely great upgrade...Are you thinking about 3D print more of those brackets? I would love to get one or two sets...
Ismar
But the license block the air flow, also the license plate can protect you from other bumper cars scratching the nose,This one lowers the plate to the grill-level , leaving the nose as-designed,
instead of the standard mount, ruining the typical view. In Holland frontplate is obligatory.
I like that option but I worry it can create rust due to galvanic corrosion in winter + humid/rain weather. I see you are in MA, have you ever checked to make sure it doesn't rust?
About 2 3/4 inches
Been running mine tilted for a year
Our plates bigger
I just got my plates for my T3D-. Any idea on how important it is to not block the airflow come next summer when it gets hot? I have the Tesla supplied front plate bracket but I have PPF on the front and don't really want to stick the tape to it. I may go naked without a plate but the state requires it (secondary offense) but places like Portland ticket heavily (meter maids will ticket you) and fine is $85.
