Front License Plate: is it too late to ask them not to screw it in?
Discussion in 'Model S: Interior & Exterior' started by Argelius, Oct 14, 2013.
  1. Argelius
    Argelius Member
    Palm Springs, CA
    Apologies if this has been answered before, but my searches didn't come up with anything.
    After doing my final paperwork, and saying it was okay for Tesla to install the Front license plate, I came across this article, which provides some nice non-destructive methods of mounting.
    Installing the Tesla Model S Front License Plate - Teslarati.com
    Are license plates "factory mounted" at the factory, or do they do that at the local service center prior to pickup.
    Just curious if I might be able to intervene....
  2. Zextraterrestrial
    Humboldt/Los Altos
    just double stick 3M or 3m Velcro it on. No damage then
    (don't see that listed there)
  3. texex91
    texex91 Banned
    hell
    They will ask you on your delivery docs if you want it on--it's done at the SC so don't worry.
  4. brianman
    brianman Burrito Founder
    I'd call them immediately since your delivery date isn't far away. My recollection is that this was a "near-delivery" (i.e. late) step but that may have changed in the last year (who knows).
  5. Argelius
    Argelius Member
    Palm Springs, CA
    Thanks -- I already signed my delivery docs (but car isn't due until next Monday).
    Annoying that the two states this car is going to reside (Illinois and California) both require ugly front plates.....
  6. tnawara
    tnawara Member
    Naperville, IL, US
    You should be fine - just let them know asap and make sure the service center (I assume that's where you're accepting delivery of the car) knows.
    BTW - I just installed my front license plate this morning:
    I used the j-bolt method and it seems to have worked well. Now I just have to drive the car with the license plate mounted...
  7. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Even if they have drilled it in fortunately they do it into the plastic nose cone which can be replaced.
  8. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    #8 Gizmotoy, Oct 14, 2013
    Do we know how much a nosecone costs to replace? I'm considering just letting them drill mine so I don't have to worry about it. I've always refused on other cars since they need to drill a painted bumper, but might be OK with it in a $100-200 plastic part that's easily replaceable.
    Edit: In case anyone's wondering, it looks like it's probably $350, based on this thread http://www.teslamotorsclub.com/showthread.php/15266-Spare-nose-cone-arrived-today/page4
  9. texex91
    texex91 Banned
    hell
    You may want to mount lower, like pictured above.
  10. Gizmotoy
    Bay Area, CA
    Beyond the slight visual advantage, it looks like there's a lot more potential for damage down there. It would appear to be resting on the painted bumper. If it moves around it could scratch it, or it will rub if the plate vibrates at all at speed. It's hard to tell without a profile, but if it someone taps it parallel parking it could damage the paint. If it's on the nosecone, you just order a new nosecone, no painting required.
    I'll most likely either mount it in the safe stock location, or go without.
  11. texex91
    texex91 Banned
    hell
    Actually you just put some foam rubber on the back so it doesn't (shows how to do that in the video). Anyway, whatever works best for you.
  12. Gizmotoy
    Bay Area, CA
    Did something really similar with a Civic 8 years or so ago. Even used the same foam from the video. 100k miles later the paint was worn off behind the foam. And that was with a plate that didn't move at all when I pulled on it. I haven't seen one up close, but I'd be concerned about the longevity of that method given it's actually resting on the foam/bumper. The foam will eventually get dirty, and then you've got trouble.
    Learning from that experience, my current car has the plate attached with heavy-duty adhesive, but that's because it has to be mounted on the side of the bumper. You can't put it in the middle because the engine needs the airflow for cooling. That seems to have worked pretty well, but it will be a pain to remove eventually.
  13. lloyds
    lloyds Active Member
    Bay Area
    Let your DS know and remind him / her a week prior to taking delivery.
  14. Gizmotoy
    Bay Area, CA
    They do. I've talked to mine twice. You didn't get a scheduled delivery time? Mine was scheduled by the DS.
