Front license plate option
Discussion in 'Roadster' started by dsm363, Nov 11, 2010.
Tags:
  1. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    I posted this in the foundry bracket thread but thought it might be better here.
    I understand that the Roadster 2.5 can come with a factory installed front bracket. I was told by Tesla that it's drilled into the black plastic insert, not the front bumper. Have any of the new Roadster 2.5 owners here picked this factory option? If so, could you post a picture? Thanks. I'm trying to decide if I want Tesla to do this or to buy the Foundry bracket from currentEVtech.com
  2. tdevince
    tdevince Member
    Columbia, MO
    My 2.5 came with the bracket in the trunk for me to install if I wish. I didn't put it on the car since I really didn't want to drill into the front grill. Installation really doesn't look like any big deal, but I decided to order the bracket from currentevtech.com that just attached to the tow hook bolt. The Tesla bracket mounts with three screws drilled into the grill along the top of the bracket. You then have to drill out the holes for the attachment of the license plate to the bracket. Attached are front and back pics of the bracket. The large hole is centered over where the tow hook bolt is located.
  3. dsm363
    Nevada
    Thanks. If they basically go in the same place, I wonder why Tesla recommends not using the Foundry bracket due to air flow issues?
  4. strider
    strider Active Member
    NE Oklahoma
    They have to say that because it's not their product, they haven't tested it, etc. We went through the same thing on the Corvette forum as GM's bracket required drilling into the bumper. An alternative was created that went into the grill area and GM warned that it would mess up airflow, etc. But I've been running it for over 4 years with no problem (granted I'm not in a hot climate but plenty of people in warmer places have run it without trouble. I would imagine it will be the same w/ the Roadster.
    This is not my car:
  5. W.Petefish
    W.Petefish Active Member
    On my latest service call one of the rangers (thanks for the idea Larry) told me I should remove the bracket, which I had attached using a couple of fender washers and some old inner tube, and have a vinyl decal made of my license plate. I am waiting for the decal to be shipped from Houston. I'll affix the decal to the front bumper and post a picture when done.
    He said that because of the heat issues I had been having.
  6. W.Petefish
    #6 W.Petefish, Sep 25, 2011
  7. zack
    zack Member
    Minneapolis, MN
    That's a brilliant solution. I wonder if my AC would work better if I removed my license plate and put one of those on?
  8. TEG
    TEG TMC Moderator
    Apparently something similar was done when the Tag Heuer Odyssey of Pioneer's Tesla went through Monaco:
  9. pgwoosley
    pgwoosley Member
  10. zack
    zack Member
    Minneapolis, MN
    I'm going to guess that the lawmakers haven't gotten out ahead on this yet.
  11. W.Petefish
    The law says nothing on the matter... that being said I keep the original in behind the driver's seat just in case a police officer asks. In general my local police don't have a problem with it, I just worry about others that don't see it so progressively.
    FYI my AC does work better after removal of the front, and very obstructive, bracket.
  12. dsm363
    Nevada
    Yeah. The DMV doesn't even have wording on their site saying that the plate has to be on the front bumper but that's how the law is currently defined. It is purposely left vague I believe which is not right. It also says nothing about the physical plate needing to be in front bumper but that's what the DMV said when I emailed them.
  13. W.Petefish
    So... I guess we'll take advantage of a vague law. :biggrin:
  14. W.Petefish
    #14 W.Petefish, Dec 5, 2011
    I recently e-mailed my reps for the Texas house and senate, that is if my messages will go through.
    We'll see what comes of this.
  15. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    This is simply bad vehicle design; many states require front plates, so the car simply has to be designed to assume that we are going to comply with the laws.
  16. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Perhaps it is a poorer design of regulations. Requiring a plate on the front at all is redundant and unnecessary.
  17. dsm363
    Nevada
    Even worse is that it's not actually written anywhere that the front plate has to be on the front bumper (which is what the police enforce). The DMV website actually says you must have one front and one rear plate "placement not defined". The actual law doesn't specify that it has to be on the front bumper and no one at the DMV can find the wording that say so for me.
  18. garygid
    garygid Member
    Laguna Hills, Orange County, CA
    I am in California.
    Would you please PM details of how you managed to order the nice vinyl plate?
    Is the vinyl base like that for a vinyl wrap, that can be applied over the compound
    curves of the Tesla S nosecone?
    Thanks, Gary
  19. tonybelding
    tonybelding Active Member
    Hamilton, Texas
    That decal is not reflective material, is it? Plates are made with directionally reflective paint.
  20. jimmyz80
    jimmyz80 Member
    Apex, NC
    My roadster (bought used) came with a front plate installed using some sort of a bracket that bolted onto the under-side of the front bumper (above the grill, flat underside of the painted panel). It looks to be made specifically for this car, since it has molded in curves that match the bumper. Since I bought the car to NC which doesn't require a front plate, I unbolted it and wiped down the paint armor surface it was covering; now you'd never know it was there.
