Hezi
Create 3 spacers from Plastic or PVC tubing. You can easily find it at your local hardware store. You can be few millimeters off on length in picture. since the plate plastic base is flexible.
Use a box cutter to create small cuts on the inner edge of the plate base and insert long zip ties (I ended up replacing what you see n the picture - 2 zips combined - to one long one on each hole).
Mark the location you intend on looping the zip ties around on the lower grill- I used light small zip ties.
From the grill, push the tie through the spacer and back into the center hole on the plate holder.
Tighten as you adjusted the position of the plate and the job is done. The plate base is firmly sitting snug to the lower grill. No hols drilled, maintaining the original configuration of the car. I hope this help!
