Front Parking Sensor Not Working?
JK929
112
28
Los Angeles, CA
Hello all!
I did a search on this topic, but could not find one in the Model Y forum...
I just realized that my front parking sensors stopped working. Last night I went out to Target and while parking, I noticed I wasn’t getting any information on how close I was to the bushes in front of me. I thought it might just be because they’re bushes and the sensors might not be reading it correctly since it’s mostly hollow. However, while parking today at work, it was not detecting the wall in front of me. It’s odd because I used AP on the freeway on my way to work and I haven’t gotten any errors about any issues with sensors.
I haven’t been able to check if the rear sensors are still working.
I’m wondering if any MY owners have experienced this so far? If so, has it been fixed?
Thanks!
Reactions: aspushkin
dkarpov
New Member
May 16, 2020
4
4
Little Rock AR
One of my rear sensors recently went out. In addition to not getting the distance to obstacle information, at slow speeds it would constantly inform me that Park Assist was not available.
Also, regular summon did not function (I didn't try smart summon), and I could not use the turn signal to change lanes while Autopilot was engaged. I do not use automatic lane changes, so I don't know if that was affected.
All of that was due to a single parking sensor in the rear being inoperative. Not having the curb distance lines was probably a contributing factor to me scuffing my wheels, too. At least that's what I tell myself.
There was no way for me to tell which sensor was out. When getting the parking assist warning, there'd be a weird red line on the avatar screen, but it would go away once I reached speed.
They replaced the sensor, and everything is working fine now.
Reactions: alexcue
ib604
5
2
Vancouver
I'm also getting similar issues with my front sensors as well. No warning as I am pulling into a spot. Rear sensors start detecting well in advance of getting close to anything. Gonna schedule a service appointment and see what they say.
Hello all!
Thanks!
JK929
112
28
Los Angeles, CA
Yeah, I’m not even getting any messages saying that parking assist is unavailable,
I also scheduled a service appointment. I wonder what the issue could be. My front sensors look fine. They aren’t pushed in or unseated from their position unlike the other Tesla owners who were experiencing this problem.
BobbyD1
54
99
SF Bay Area
Hello all!
Thanks!
This is happening to me as well. Rear sensors working but fronts are not. Took it in for service and they replaced something and said it was working but it's not in fact working. Do you have PPF on the front by any chance?
Gigaron
283
124
San Francisco
I was having problems front and rear with no errors until the PPF was cut away from them. Started happening around a month after it was installed.
cwinsc
7
0
SF Bay Area
For my Model Y, the front parking sensors seem to work during the daytime, and at night time while pulling into the same garage spot, front sensors don't work.
Do your front sensors work during the day and not at night?
ib604
5
2
Vancouver
JK929 - Any resolution?
I haven't made an appointment yet. But I do have ppf. So wondering if that's the problem. Although I have a full vehicle wrap, so wouldn't it effect the rear sensors as well? Seems isolated to the front 2 middle sensors.
origingalatic
236
145
new york
If you have PPF, they may get dirty and impede the sensors. I find that the sensors on Tesla seems to only warn you when you are very close compared to BMW's as an example.
Someone mentioned about AP is fine but sensor is not. AP does not use these parking sensors... they are too short of range to allow any actions at high speed.
Reactions: ib604
BobbyD1
54
99
SF Bay Area
OK, for posterity. Cut holes in the PPF covering the sensors and problem was fixed 100%. Theory: after curing or after enough sun exposure some PPF will begin to block the sensors, even if clean. My car is not driven that much and otherwise in a garage so took a few months to interfere with the sensors. Thanks to those helping out on the thread.
Reactions: alexcue and ib604
cwinsc
7
0
SF Bay Area
Thanks for the update, did you remove the PPF from the front sensors entirely?
BobbyD1
54
99
SF Bay Area
Yes. The guy who installed it did careful round cutouts, just a hair outside of the outer edge of the sensor.
N3rdJustin
New Member
Apr 12, 2018
4
Calgary AB, Canada
I had PPF installed. It covered all 6 sensors on the front (4 forward facing and 2 front corners). Corner sensors kept working but the front 4 stopped. Talked to SC and they let me know the front 4 have a different part number from the rest, speculation is that they are more sensitive.
I cut holes in the PPF for the front sensors and they immediately started working.
Reactions: Gigaron
aspushkin
42
16
SF Bay Are
Same story. XPEL stealth, worked fine at first, 2-3 months later front middle sensors stopped working, no error, no warnings. Today, cut off parking sensors and everything is back to normal.
