Front scoops=Functional?
Discussion in 'Model S: Interior & Exterior' started by gctseng, Jun 25, 2013.
  1. gctseng
    gctseng All around good guy
    United States
    Hey all, Been driving around with the S for a couple of days and now trying to figure out the nitty gritty. One thing that I can't figure out is if the front scoops actually do anything. They seem to be blocked with a plastic cover, and I'm guessing the S doesn't need that much air for venting.
    Anyone clear the air for me?
  2. DrComputer
    DrComputer Active Member
    Sherman Oaks, CA
    Those are louvered doors that allow (or block) air from passing over the radiators for the cooling system. There are three radiators in the front of the car, one on each side behind the louvers and one in the center behind the nose cone. The louvers stay closed for better aerodynamics until the heat load dictates they open for maximum airflow.
  3. Volker.Berlin
    Volker.Berlin Member
    I haven't seen them in action but it is said that those blinds open and close as required: Open to maximize cooling effect and close to optimize aerodynamics/maximize efficiency.
  4. pete8314
    pete8314 Vendor
    DFW
    you must live somewhere that's a bit chilly, mine are open most of the time at the moment (maybe not when I'm driving, but certainly every time I precool the car). Current interior temp: 133f.
  5. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Pete, Do yours open as a pair? Only one of mine opens.
  6. gctseng
    United States
    Ahh. Okay. It was about 7 am when I took that picture in Pasadena, so it was def still cold. The reason I ask is because I'm thinking of putting a parking sensor there and didn't want to plan on it off it was not feasible
  7. William13
    William13 Member
    South Bend
    #7 William13, Jun 25, 2013
    One side is for battery heat pump. The other is for cabin heat pump. They may not work in synchrony
  8. pete8314
    pete8314 Vendor
    DFW
    I tried to get a photo, but by the time I got the car out of the garage, they'd both closed. William is right, sometimes I get 1 open, sometimes 2, I guess it's been hot lately (my cars sits outside all day long during the week), so both are always open at lunch and when I'm going home.
  9. Lloyd
    San Luis Obispo, CA
    Thanks, I saw one side open with supercharging, and have never seen the other open.
  10. SCW-Greg
    SCW-Greg Active Member
    Beaverton, OR
    What's the main radiator for, that's needs to be that big then? Motor and inverter cooling?
  11. NigelM
    NigelM Recovering Member
    Sarasota, FL
    Drive around on a hot day and then put the A/C on "Lo" and take a look, you'll see them both open.
  12. mknox
    mknox Well-Known Member
    Toronto, ON
    Interesting... I don't think I've ever seen mine closed. Gonna have to investigate more closely...
  13. GasDoc
    GasDoc Member
    SF Bay Area
    Here's a pic of a teardown showing the three radiators. I'll have to visit my car in the shop and take a close look at the parts to see if I can snap a pic of the louvre mechanism.
