Front seat belts rub against neck - very bothersome
Discussion in 'Model S' started by TLee, Jul 5, 2015.
Tags:
  1. TLee
    TLee Member
    Trafalgar, IN 46181
    We have a new Model S 85D with only 250 miles on it. When the front seats are adjusted for the best positions, the edge of both the driver and passenger seat belts rub firmly against our necks. This is going to be a problem on anything but very short trips. Does anyone have any suggestions for a newbie?
  2. andrewket
    andrewket Well-Known Member
    Sounds as if you need to raise the seats?
  3. Dbitter1
    Dbitter1 Journeyman Member
    Chicago, IL
    My wife complains about that, too. I think this (adjustable seatbelt) would fall in the list of stuff Tesla will hopefully include in future models... it is standard on every luxury car I know of and a lot of the economy cars, too...
  4. Bonlaw
    Bonlaw Member
    Orange County, Ca
    Go to Peo Boys or the like. They have sheepskin that covers the strap.
  5. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Search Amazon.com for seat belt shoulder pad or similar and you will find lots of products. My wife got one and finds it really helps. She is short. I am tall and don't need it.
  6. smsprague
    smsprague Member
    Prescott, AZ
  7. andrewket
    My wife is 4'8" and doesn't have this problem. Are you sure you can't raise the seat more?
  8. gzerninplatz
    gzerninplatz Member
    Troutdale, OR
    that Masterlink thing seems to defeat the whole seatbelt safety idea - it puts what amounts to slack in it - in an accident that thing wouldn't keep you secure...
  9. youpidou
    youpidou Member
    Switzerland
    It really sounds like you need to try raising the seat, even if this new position takes some getting used to. I'm rather short (160 cm) and have no problem with the seat belt rubbing. My seat is adjusted quite high, which also gives me better visibility on things.
  10. AudubonB
    AudubonB Mild-mannered Moderator Lord Vetinari*
    I'm 6'0" and I complained to Tesla about this last year, wondering whether our vehicle's belt had an unwanted half-twist in it. Service Center determined ours was no different from any other vehicle, so nothing was changed. The belt would, I believe, have to be altered at the base, spring winder level, with that element being turned 180º...and that is more than a ten-minute procedure.
    It frustrates me to the extent that about 1/4-1/3 of the time that I'm driving, I give it the desired half-twist myself up at the shoulder, which then makes for an unwanted, unstable, and probably dangerous-in-a-crash half twist right at my belly.
    I don't understand it. Providing that half-twist allows the belt to lay flat against the upper torso-neck area - it must be a safer, more natural attitude. I have been awaiting another's input into this situation to provide my own experience, so I thank the OP for initiating this thread.
  11. mknox
    mknox Well-Known Member
    Toronto, ON
    For me, it just happens to be at the right height, but it is odd that they aren't height adjustable like just about every other car. Just yesterday I happened to notice a passenger was holding the belt away from his neck on a short trip we were making to the store. He said it was in a kind of awkward spot on his neck.
  12. 1NJ85D
    1NJ85D Member
    Scotch Plains, NJ
    I am not THAT short (at 5'9) but this is a problem for me as well.
    I purchased Amazon.com: Masterlink Marketing Black Seatbelt Adjuster, (Pack of 2): Automotive but it raises the horizontal portion of the belt, positioning it over (and not under) your abdomen, which makes it dangerous.
    If I raise the seat, the seat doesnt bother me as much but I then get very poor visibility on the internal rearview mirror (the window on the back is too small/short).
    I have been able to squeeze a small improvement by moving the seat as back as I could (and adjusting the steering wheel as well).
    I have not tried the pads.
  13. Spidy
    Spidy Active Member
    EU
    There are probably very strong safety regulations at play here. And they are not going to change anything to something that has not been extensively tested. And even a 180° switch could change the forces at work.
  14. AudubonB
    Yes, I agree. It doesn't explain why that half-twist is there from the outset, however.
  15. Galve2000
    Galve2000 Member
    NYC
    +1
    334 Miles as of this morning. I'm constantly pulling the seatbelt bc it keeps chafing against my neck. it's getting bothersome.
  16. markb1
    markb1 Active Member
    San Diego, CA
    Can you post a pic? My seat belts don't seem to have a twist, and I think I would notice. That sort of thing would drive me nuts!
  17. taurusking
    taurusking Member
    East Texas
    My wife also complains about the seat belt all the time...:redface:
    I hear her say all the time "100K car and still they don't have seat belt adjuster"
    I choose to ignore her :biggrin: all the time but I guess seat belt adjuster listed on amazon might be a solution.
  18. TLee
    TLee Member
    Trafalgar, IN 46181
    Other seatbelt options.
    Thanks to all for your suggestions. I have ordered these seatbelt clamps, though I realize that using them will compromise the crash performance. But, the 'cutting into our necks' issue is significant enuf for us to try this as a remedy.
    - - - Updated - - -
    Oooops - here is the item = Traveling LooPo (2-Pack) Seat Belt Adjuster. Amazon has them.
  19. Johan
    Johan Took a TSLA bear test. Came back negative.
    Drammen, Norway
    I agree with your experience. However I would suggest that twisting the base 180 degrees would only result in the same experience of the belt wanting to twist 90 degrees (to be at an angle to the skin as opposed to tangential). This happens because of the orientation of the linear outlet hole for the belt up by the shoulder. If you twist the base 180 degrees you'd probably experience the belt wanting to twist 90 degrees in the other direction but with the same result: edge against the skin at an angle.
  20. deonb
    deonb Supporting Member
    Redmond, WA
    Am I the only one here who still prefer suspenders?
