Front splash guards not connected on the bottom?
Discussion in 'Roadster 2008-2012' started by tvuolo, Mar 10, 2015.
Tags:
  1. tvuolo
    tvuolo Supporting Member
    Colorado
    I noticed the front splash guards are loose at the bottom on both sides of my 1.5. Is this normal, or should they be attached in some way down there? Maybe "splash guard" isn't the correct term, so please correct me. It's the plastic bit between the front of the car and the tire.
  2. tonybelding
    tonybelding Active Member
    Hamilton, Texas
    For whatever it's worth, the seem to flop around fairly loosely on my 2.5 as well, and I had wondered about this too. I decided it's probably made that way on purpose -- if they were secured, they'd more likely end up breaking or tearing off.
  3. Gary1M
    Gary1M Member
    Orange County, CA
    Just checked my 1.5 and it looks exactly the same.
  4. ML Auto
    ML Auto Member
    SW Florida
    They are kept flush on the outside (paint side) by adhesive tape, but only the shape of the rubber holds them in place on the lower portion pictured. The older they get the more they get distorted. You can use some clear silicone to secure it back in place if desired.
  5. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    There are 3 10mm bolts that secure the bottom so they be should be attached. The bolts are not easy to see or get to with the folks 8 the rubber.
  6. spaceballs
    spaceballs Member
    Sammamish
    Are you sure? here is my old bad one, I only see three holes on the side, and one on the bottom to connect it to the car.
    btw the replacement part number is "SPAT W-ARCH FR RH (6003372)"
  7. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    There is a double-sided foam tape strip that helps keep the splash guard in place. It tends to get pulled apart - especially if your mud flap bottoms out (a not-so-rare occurrence). I think it's that grey strip inside the guard in your pictures.
  8. tvuolo
    Colorado
    That's a pretty good idea. I'll clean mine up, use double sided tape, and report back. I have some of the tape used to apply letters to the car. That should work.
  9. dhrivnak
    NE Tennessee
    You are correct and I was wrong. There are 3 screws on the side and one on the bottom.
