Anyone else feel that the front suspension knuckles are too close to the top of the tires? Seems like there is only a gap of about an inch.
I have the stock 18" Aero Wheels and it's the AWD car.
If your front suspension knuckle hits your tire something has gone very wrong and more clearance is not going to help.Anyone else feel that the front suspension knuckles are too close to the top of the tires? Seems like there is only a gap of about an inch.
It's the same way on Model S. A Miss is as good as a mile one inch is all you need. they're never going to hit or come in contact unless there's some type of a failure in which case you were not going to do good anyway so it doesn't matter.
The only difficulty would be is if you wanted to put oversized wheels / tires on the vehicle otherwise it's a non-issue
Why would I think that?Anyone else feel that the front suspension knuckles are too close to the top of the tires? Seems like there is only a gap of about an inch.
FYI The owners manual says not to put chains on the front wheels.Plenty of room for chains
Not that I was planning to put chains anywhere. I have studded snows, and have only needed chains ONCE, many many years agoFYI The owners manual says not to put chains on the front wheels.
Yes, it is rigidly connected to the hub.Thanks for all the responses. I figured it was okay, just not used to seeing metal so close to a tire. Am I correct and thinking that the knuckle also moves up and down, in unison with the tire?
