Front vibration when accelerating - accelerometer graphs....
sorka
7,618
5,645
Merced, CA
They fixed the noise but I've had this vibration between 35 and 50 MPH during full force acceleration that is only getting worse.
Tesla said they can't feel it when test driving it.
The vibration is lateral from side to side with a little bit in the forward direction. But because it's mostly lateral, something is disturbing the acceleration force on just one side.
Frequency is 28 HZ. Total lateral g-force acceleration is 0.8 gs. It's a pretty strong vibration.
Here are some charts. The blue bulge in each is the vibration.
I used the app called Accelerometer Meter in the Google Play store. Anyone care to download it and take a run from 0 to 50 MPH. If you send me the file, I'll produce the graph for comparison.
rns-e
459
119
Denmark
I also have vibration in the front when accelerating full power, have not been by Tesla yet, but have informed them. Have had it for 1.5 months now. I also have a lot of vibration when braking hard from high speed. I do not think it is the brake discs, as there is no vibration when braking more gentle. Further more i have a clicking sound from the front when turning at very low speeds. It somehow sounds like there is play somewhere in the suspension.
Other than that, it feels great :)
sorka
7,618
5,645
Merced, CA
Can someone who doesn't think the have the vibration with a PD car download:
Accelerometer Meter - Android Apps on Google Play
to their android and grab a few 0-60 runs? It could even be 10 to 60 or a soft start 0-60. No need to slam it. It just needs to be full acceleration within a second or so.
I held my android on the center console sliders facing up with the top of the phone facing forward.
I'd like to get some data from a car that doesn't have this issue so I can forward it to Tesla and show them it's not normal.
sorka
7,618
5,645
Merced, CA
Can't make sense of it's The Y axis is pulling at least 1/2 g when it looks like it's not really accelerating. The X axis should be circling 0 plus or minus but it's almost always positive. Were you taking a hard corner?
The app should look like this if you're sitting still. X and Y at 0 and Z at 1.0 g. If you hold the phone facing up flat down on the center console armrests with the top edge of the phone pointing forwards to the front of the car, you should produce data where Y goes from 0 to some positive number. It should max out around 1.1 (Insane or Ludicrous). Ludicrous will max out longer.
The app should look like this sitting still facing up:
sorka
7,618
5,645
Merced, CA
Mine started a few months ago. I wonder if it's just really common. I'm going to have to do runs with an IMU attached to each Hub and see if it's primarily on one wheel which I suspect it is given the lateral acceleration.
So I just realized my lateral acceleration shimmy is pulling twice as many gs as yours. Your total g diff is about .35 while mine is 0.9.
sorka
7,618
5,645
Merced, CA
I'm going to attach an older smartphone directly to the hubs tomorrow and do runs one each to see if one axle is worse than the other.
StaticDischarge
Utterly Unknown....
Mar 25, 2015
56
48
Edmonds, WA
I did a few more runs with substantially the same result. Below is an example with two periods of acceleration, one low, the other high. There is some increase in x axis noise with lower acceleration, but there is also an increase in z axis noise. Unclear if I hit a critical speed (if there is one). The high acceleration shows the x axis noise (and shudder feeling); z axis stays noisy but does increase, perhaps not quite in sync with the x, hard to tell. High acceleration period was short as I was running out of road, too many cars. I plan a run on the freeway to see if full power will induce the shudder at a higher speed. I was typically going about the same speed on previous tests. Perhaps it will repeat at higher speed, perhaps not.
Looking forward to the axle results.
sorka
7,618
5,645
Merced, CA
I wonder if all of them do this at say the total .4 g spread that your seeing and I'm only noticing because it's worse at .9 gs?
Anyone else care to try. It shouldn't take more than a few minutes of time.
hiroshiy
2,376
1,476
Tokyo, Japan
Hi, @sorka, I tested but my car is 2014 P85 RWD and under full acceleration the rear tires had some wheel spins and my Android phone went from LCD screen up position to LCD down position, in the cup holder, so you see some Z axis movements too. I can retry if you tell me how not to let the phone move there.
  • Accelerometer Data 2016-07-06 10-21-12.txt
StaticDischarge
Utterly Unknown....
Mar 25, 2015
56
48
Edmonds, WA
I did a higher speed run - started at 50 mph, applied full power until I was going about 74 mph. I didn't feel a shudder. Graph suggests the vibration didn't occur. So perhaps it only occurs under full power in a lower speed range, as suggested previously.
Reactions: sorka and hiroshiy
sorka
7,618
5,645
Merced, CA
Just a quick update. A few weeks ago the same Tech who looked at this the first time drove it and confirmed the shudder so I'm secheduled for 8/11 for them to take another stab at it.
sorka
7,618
5,645
Merced, CA
No chance. Long after peak torque. In fact torque is half of peak by the time the vibration starts. Also there is no cut in power like there is when traction control engages. Lastly it feels nothing like wheel spin.
