Right from the start when I picked up my 2020 MX in Dec 2019, I felt a slight "tire imbalance" at speeds 40-plus. I ignored the issue until I was leaving for a long-trip through the mountains and wanted to be safe. Tesla balanced the tires. Vibration still there. Purchased a new set of tires. Vibration still there. Went on this trip with the vibration. In the mean time, this vibration has created these repairs: replaced clunking left adaptive air-spring module, both front semi-axles only because the left one had deteriorated, grinding outer ball bearings, front gearbox pump, dropped harness robbing on left tire. The car also developed a metal-to-metal clunking noise going over small bumps that they cannot identify and fix after numerous trials. I am stuck. The vibration is rhythmic and synchronic at all speeds but better heard, felt in the steering wheel, seat, and floor at speeds 70-plus. At speeds 85-90 and higher it feels like a very bad unbalanced tire. The car is only 35,000 miles. I give up and I thinking to file for a lemon law. Any ideas what it might be? Any idea if Tesla is hiding the real problem and excusing it by "it's just the normal operation of the car and we cannot legally drive the car more than 70 mph, and it's safe to drive?" This has been the worst customer service and cover up I have ever experienced: arrogant and incompetent. Is it the motor or anything else? This vibration will continue to deteriorate front parts and cost me an arm and a leg when it's out of warranty. What do you all see, know, and could advise me? Thank you.
Hi, did you ever get a fix for this? I've been having the exact same problem for a while now with my MX LR (from Dec 2019). Small vibrations which can be felt through the steering wheel and the seats. Theay are also rythmic in nature. I get a feeling they are from the front but I'm not sure. My SC has looked at it and they can not fix it. I have been having a lot of shudder also. My front half shafts has been replaced three times. SC blames tires but I think it sounds unlikely since I have had the problem with both summer and winter tyres (studless). A tire shop has checked the tyres between season changes also, the tyres are round and balanced. Since my car has been to SC a lot I have been driving different MX loaners (pre Raven) who have been silky smooth but the general feel of the suspension is better in Raven. Is it a Raven Issue?
It might be a Raven issue. Thanks for sharing. I have someone else in this area that I am talking with about this issue who has the same model, and the problem is exactly the same as mine and yours. It seems to be an issue that Tesla knows about, but they are not letting customers know and they keep on blowing us off by replacing a part or so and sometimes refusing to service the issue. I talked with the general manager from this area and he just plainly refused to do anything else. It seems that they know about this issue but they only comment in their internal documents but not in the customer's invoices. They simply deny the problem (ie: we cannot drive the car above the speed limit or saying that the car is safe to drive), and do not acknowledge the issue. Both managers from Fort Worth Service Center and the Dallas one, are in unison talking with each other and covering it up. I tried to get it replaced under the lemon law but the car is way passed the 24,000 miles limit in Texas and I will be out of the 50,000 miles warranty soon. The law firm can pursue the warranty issue but they cannot guaranty any results because of the Texas Lemon Law limits. Its at the mercy of Tesla. It will hit my pocket hard. This entire service is just unfair. The MXs are great cars; love them; but the service and their treatment of customers (many that I know) is arrogant and dismissive. I have never seen more incompetent and arrogant customer service, especially the managers. At this time, my only option is the courts. I simply want to drive a normal car and get it fixed, if needed, and move on. I class action lawsuit might be the only option in dealing with this. Any other ideas?
It sounds like you guys are describing the shudder problem?: The shudder problem: Current status (end of February 2020)
I previously saw the post your are referring to, and I read a lot about the shudder problem and this is not it. The problem with my front vibration is not when I accelerate. It is a rhythmic imbalanced vibration at any speeds and even when I am not accelerating at all. It seems to be an unbalances part/thing in the front driving axle, unrelated to the tires or reams. Mine is mostly on the left side. It has been the cause for many repairs already: replacing the front axles because it shuttered the left outer ball bearings, the adaptive air-spring module, front motor pump, and it has created a metal-to-metal clunking on the left suspension. Now, I am again hearing the left side ball bearings when accelerating. I haven't taken it for service, yet. All these repairs were made because the car has this mysterious front (slight) vibration at low speeds, and at speeds higher than 70-75 it sounds and feels like an badly unbalanced tire.
First, I have no solution but curious at what point did this start? If I read you post correctly in one year's time you put on 35000 miles. Did you notice this issue shortly after purchase or did it develop over time? Has it gotten worse or remains the same? Is there a place where you can safely coast in neutral to see if there is a difference? I really do not know if the motors are connected in neutral but trying to determine a balance issue in a rotating component. Is it better or worse if regenerate is set to normal or min?
Just read another input on FB. Seems it's a warped front rotor. You CAN'T find a warped rotor by spin balancing your tires. Best way to check it is to put on the brakes and see if it exacerbates the vibration.
Steinmetz, It was like this from the start, from the moment I got on the highway after I picked it up. I thought it was an unbalanced tire. Then, I thought it was a bad tire. Then, I thought it was the front axles. The vibration pretty much remained the same. It didn't progressively gotten worse; if it did, it is very, very little. I think this could be some sort of unbalanced rotating component but not the axles. After the front axles were replace, the vibration didn't change a bit. I am speculating here: it could be the "housing" that locks in place the axle coming from the motor, or it could be the motor itself that vibrates because it is mounted just a touch off from where it needs to be. Also, thanks for the good advice. I will put it in neutral and see what happens.
Dominik_12, I don't think it's the warped front rotor, or any rotors because when I brake, if I have to use the brakes, it's very smooth, like no other car. I usually have the car in standard regenerative mode and I hardly use any brakes. Well, great thought, though. Thanks.
I just changed the two front tires yesterday and today while driving on the highway the car vibrates. Feels like the tires need to be balanced or like the lug nuts are loose. I will take it back to the service center to check it. I am hoping is just a bad balance job and something else did not pop up as in the previous posts. Also the TPMS sensor shows about a 10psi difference between the two front tires, I doubt this will cause it but I will even out the tire pressures tonight. Any other suggestions? (2018 X with 20'' wheels)
