Frunk Guts
Discussion in 'Model S: Interior & Exterior' started by pete8314, Feb 25, 2013.
  1. pete8314
    pete8314 Vendor
    DFW
    I've had a couple of PM's about some of the photo's I took while installing the Passport 9500ci, so here's a few photo's of the frunk guts, in case you're interested....
    The fully dressed frunk, nothing to see here...
    The frunk bucket. Held in with bolts, and very easy to remove.
    the so-called firewall. I never did find a convenient way through it to run my cables, but the 'droopy' drain line dead center is easily visible on both sides (behind the touchscreen on the inside), but I didn't want to drill any holes. I assume the shiny tank at the top is for the air suspension?
    This shows the fan by the wheel well, and explains why the external covers have a mesh over the front wheels to allow airflow.
    Frunk, from behind.
    The best pic showing all the mechanicals below the frunk.
    I don't know what this widget is, but it looks intriguing.
    These were all taken with an iPhone, so the quality isn't amazing, but if you want the higher-res versions, they are here.
  2. montgom626
    montgom626 Active Member
    Wow! Nice photos
  3. Thumper
    Thumper Supporting Member
    Corvallis, OR
    Nice shots, could be helpful someday. Thanks for sharing.
  4. pete8314
    pete8314 Vendor
    DFW
    I'm wondering if that last thing is the antenna for Homelink...would make sense, based on it's location, and it's 'antenna-like' looks.
  5. araxara
    araxara S-P85#3,218 X-90D#3,299
    Tucson, AZ
  6. montgom626
    Are you going to be able to put it all back together without a leftover nut or bolt???
  7. pete8314
    pete8314 Vendor
    DFW
    Already done, no issues at all, but I took my time.
  8. artsci
    artsci Sponsor
    Timonium, Maryland
    Did you happen to notice where the horn is? Couldn't see it in the photos.
  9. pete8314
    pete8314 Vendor
    DFW
    No, now you mention it, I don't remember seeing it at all. I would guess its tucked under one of the light clusters.
  10. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Where was that widget located? It's hard to tell from the pic.
  11. mitch672
    mitch672 Active Member
    Stoughton, MA
    Wow, an amazing amount of "Junk below the Frunk" :). Amazing array of pumps, valves and wiring. One is definitely the coolant pump, you can hear it spooling up when charging starts (At least i can over on here on the east coast with 20-30 degree temperatures).
    Did you take detailed pictures of the 9500ci wire runs/sensor mounting? I am considering the same detector.
  12. EarlyAdopter
    Redmond, WA
    Ah, yeah there it is. Same doohickey on the rear bumper.
    I'm no antenna expert, but I've only ever seen circular antennas for UHF. Might this be something else? That shape and size says "induction loop" to me.
    An easy test would be to disconnect one and see if the car still detects the fob fore or aft.
  13. montgom626
    Did you find fuse box #1? I saw fuse box #2 and #3.
  14. pete8314
    pete8314 Vendor
    DFW
  15. montgom626
    Wow, if you had not circled the fuse box #1, I would never have guessed that that was it!
    PS Upon further review, that is not the fuse box.
    - - - Updated - - -
    Another question, how much time did it take you? Any challenges????
  16. pete8314
    pete8314 Vendor
    DFW
    Ha, sorry, no idea what happened there, I posted that reply ages ago. The bit circled is the strange little antenna that's replicated behind the rear bumper.
    - - - Updated - - -
    I think fuse box 1 is somewhere near the battery, which is nicely buried in the top left corner of the frunk (when viewed from the front).
    - - - Updated - - -
    You can find all the details of my 9500ci on this thread. There's a LOT of wires to vanish, but if you take your time, it's no problem. I've installed plenty of screen-mounted detectors, but this was my first discreet install.
  17. Chgd Up
    Chgd Up Sig 1004
    United States
    I did the same tare down with Pete's tutorial and it went well. My only note is that you have to take some care when replacing the manual frunk release cable. It runs down the passenger side top of the frunk well. If you don't position it well the frunk latch will no longer latch. Not a big deal just make sure to clip it in place with as much cable up front as possible.
    My goal was to get some more sound isolation on the suspension air compressor and air conditioning compressor. I have to say both are already very well isolated from the vehicle by Tesla.
