My false "loose frunk" messages have continued intermittently, as well as other (apparently) false alarms. There was a period of nearly 2 weeks between the first instance and the second, but now they are occurring more or less regularly, but not every time I drive. In the past few days, I have had groups including the loose frunk, low coolant (scary!), and then my security alarm sounded several time when parked after the frunk and coolant alarms.
Two other failures are part of the group I see: The AutoPilot cannot be activated while the frunk and coolant alarms are displayed. Plus, the right turn signal does not actuate the visual indicator on the instrument cluster display and dose not make any audible sound. The left turn signal displays normally. I have not been able to determine if the right turn signal is working and simply not displayed on the screen, or not working. I tried actuating the emergency flasher and got out of the car, and all four signals are actually flashing.
Yesterday I made 4 trips with the car. In the first, second and third trips, we got the false alarms. the security alarm sounded at least once between the first and second trips (while I was at church -- not good!) and again at least twice after the third trip. The fourth trip proceeded normally, with no false alarms, and AutoPilot worked. But overnight, the security alarm actuated at least once.
The security alarms turn off by themselves after a few seconds, but are obnoxious to people, so after it happened a few times, I shut off the alarm in the Security panel in the MCU.
Meanwhile, I have made a service appointment. The first I could get is two weeks from tomorrow. Initially I was scheduled for mobile service, but when I modified the appointment to add the security alarm, it was switched to a service center -- not sure if that is coincidental or reflects the larger scope.
I hope it turns out to be a faulty ground (as suggested by another similar thread), because that sounds straightforward to fix. But if it is the frunk latch, I am not sure how that would tie to the coolant level or AP problems.
Here is a link to the thread with the discussion of the faulty ground issue:
Ground Stud Nut over torqued
