I was removing panels in the Frunk area near the 12 Volt battery/air inlet. I found Part Number 1131205-00-C >PP-GF20< , broken and seems to be poorly designed. The Assembly, which has two parts is joined by a (3) very slim silvers of material which its not structurally strong enough to hold up to pushing a panel fastener in and not allow the panel to be fully fasten. You may what to check yours (theirs (2) of them. (Needs to be redesigned)
Frunk Reinforcement Assy — Postimage.org
IMG 7076 — Postimage.org
IMG 7075 — Postimage.org
Haven't heard back from support. I designed a fix, printed it out 3D and bonded it to the upper portion of the part. I looked at the other part in the car while i was installing my upgraded part and it was in failure mode.
other part: IMG 7083 — Postimage.org
other part: IMG 7082 — Postimage.org
3D part bonded to other part: 3d upgrade part — Postimage.org
Basically these parts prevent the top panel cover over the fresh airlet allowing the front panel fasteners from engaging. So if if you hear flapping on the under frunk hood this is could be the problem
