Frunk tub removal
Hsuester
56
61
SF Bay Area
Was the ebay filter like an OEM that Tesla used or did someone make it just to fit to size?
I bought and installed the E-Bay filter a few weeks ago. It's not OEM but looks the part and fit perfectly. There was someone who complained on Reddit or here about their E-Bay filter getting cut by the service center. From the photos they shared, it appeared to me that the filter split along one of its folds because it couldn't handle the pressure. I haven't checked the filter since installing but I assume it's fine.
Hsuester
56
61
SF Bay Area
This is a photo of the E-Bay filter from the E-Bay posting. It looks exactly like the filter that I installed. Someone posted an image of the same filter where it appeared to split along one of the horizontal seams. From memory, I think the OEM filter did not have these seams and the folds of the filter were spaced out more.
HappyHappy
108
95
San Diego
So I looked at that thread, and posted there too. The eBay seller's photo looks like it has a weak spot in the filter right where it split in that Tesla Forum post. If you're bored, you may want to take a look at yours to see if it has the same problem. I bought from the same seller, and received a slightly different design. Both sides now have a crosshatch pattern for extra support.
Reactions: Hsuester
daktari
747
897
Norway
So I looked at that thread, and posted there too. The eBay seller's photo looks like it has a weak spot in the filter right where it split in that Tesla Forum post. If you're bored, you may want to take a look at yours to see if it has the same problem. I bought from the same seller, and received a slightly different design. Both sides now have a crosshatch pattern for extra support.View attachment 248413
From your picture it seems to be without a frame with no clik locks or latches? You just push in in to fit tight?
eddielee1970
New Member
Nov 8, 2017
2
0
Woodinville
Can someone post a dimension of the ebay model X filter? someone posted that HEPA filter for model S was 14" x 27.5" x 1", but HEPA filter is much bigger then what posted.
teethdood
392
524
Visalia, California
This image shows the filter being installed backwards. The black felt liner on the rim should be facing the windshield, not toward the image. Just FYI.
