FS: M3 both front control arms and compression arms (used - good for use if installing solid bushings)
Sam1
2,603
2,652
NV
Just pulled off a set (both sides) of compression arms and control arms off a model 3. Main bushings on both are ripped and/or exhausted. This would be a good set of arms to use if you were planning on installing the solid/spherical bearing kits and didn't want your car to be on jack stands while you get the bearings pressed in on your existing arms at a shop or whatever.
$100 shipped to the lower 48
