FS: Model 3 AWD MPP BIG BRAKE KIT w/ TRACK PADS - $1500
boostftw
53
107
Fremont
Price:$1500
I'm selling my AWD Mountain Pass Performance BBK Rotors 365mm front rotors and MPP track pads. They were mounted on my P3D- (stealth) and will also fit regular AWD models. Literally new... no track/mountain runs or anything. I've decided to go a different route and these are now for sale. I paid over $1750 for this setup and it has less than 2k daily driven miles on it, great deal for anyone that wanted to upgrade to this setup, you can now save some money.
  • Massive upgrade to cooling and stopping power
  • 365mm diameter vs 320mm OEM rotors
  • Lightweight, 3.41lbs lighter each
  • Visually stunning two piece rotor
  • Aluminum anodized hat made from US-Sourced 6061-T6
  • Directional rotors with curved vanes for optimal cooling
  • Made in the USA
  • Rotors made by a leading brake supplier with winning experience in the highest level of motorsport.
  • Tested on the racetrack by professional drivers – these discs with some good pads and fluid is all you need to be able to run all day at the track.
  • For use with 19″ wheels or larger ONLY
This kit includes the following:
  • (2) Rotor rings and rotor hats assembled and ready to be installed on the car. They are directional so be sure to install them on the correct side!
  • (2) Caliper brackets
  • (4) Caliper bracket bolts
  • Set of Front Track Pads
