FS: Used 22" OEM Model X Rims $1200, Colorado
These are used (about 20K -30K miles?) OEM 22" model X wheels. At least 1 tire needs to be replaced, It could be 2, I would be super surprised if it was more than that. I won't want to ship them so I priced them to entice hopefully a local transaction (Castle Rock Colorado, but I can easily meet someone anywhere between colorado springs and denver).
The good, I don't see any curb-rash, i didn't clean up these rims but everything on the rim looks good. The 3 tires in good condition are at 7,7,6 (32nds of an inch) of tread (in the middle, no visible uneven wear). The tire that needs to be replaced is at 5/32 of an inch. All the wheels have the tire pressure monitoring sensors.
The bad, at least 1 rim needs a new tire, it might be 2. I think one wheel has the dreaded foam that has separated and made for a harmonic residence (shaking) that's pretty noticeable between about 55 mph and 65 mph. I also noticed when I took these pictures one of the front tires has a bulge on the side wall. I think this is the tire that was causing the shaking, but when i got new wheels put on and the alignment checked the back passenger side wheel was slightly out of alignment. If that's the case you'll need 2 new tires, but I have these wheels priced as if they didn't have tires. Also I do not have the center caps or the lug nut covers. New set of center caps look to cost $40 and new lug nut covers look to be about $20.
Hoping for local, Colorado buyers!
