FSD - Change lane without NOA
VanillaAir_UK
6,936
4,478
Surrey, UK
Manually instigated auto lane changes are not restricted to NoA. You can do them on many dual carriageway roads. But its a guessing game where they work and where they don't and can change from version to version.
If a lane changes does not work where you expect, first thing to do is to quickly wiggle the steering (you soon get the hand as to what is enough and what is too much) before it times out midway through the lane change and throws you back to where you came - and you thought that phantom braking was scary!
stigmeister
94
59
Chester, UK
I always thought this was map limited? i.e. it was always consistently working or not working for me on particular routes. i.e. as if the AI was using the map to detect multiple lanes, as opposed to what it could 'see' through the cameras?
Dilly
1,345
995
Norfolk
Yup. Had that. Fortunately I choose moments when no-one’s around.
I’ll give my local non-NoA dual carriageway a try tomorrow to see if I can master lane change.
Tony Hoyle
856
525
Stockport, UK
I've never worked out what the criteria was for auto lane change to work. Perfectly good roads for it and it won't (even with dotted lines etc.) but other roads that I'd think of as less suitable it works fine..
I assume it's categorised by software somehow (rather than a tesla intern manually going through each road) so there must be a criteria.
CMc1
supercharge.info editor
Aug 2, 2019
1,338
1,163
North, UK
When not in NoA, is there another way to disengaged AP without wrestling the wheel while leaving TACC in place
Right stalk up to the first detent? (Just before Neutral). Works for normal AP or TACC, can’t confirm for FSD.
Dilly
1,345
995
Norfolk
Tried giving the wheel a wiggle on my local non NoA stretch of dual carriageway and auto lane change worked fine. Thanks for the heads up.
JupiterMan
421
364
Hertfordshire, UK
Coming back on the A14 last weekend NOA was enabled most of the way, there are very short patches however where it was not available - these seemed to be for junctions which were perpendicular (i.e. not slip roads), NOA then re-activated when passing that junction (guess this makes sense, as car not yet able navigate off road for such sharp junctions automatically)
Lane change however did continue to work on request through these sections.
Similar thing with tunnels, on the A1(M) Potters Bar tunnel, NOA disengages, but you can still request a lane change through the tunnel no problem.
I've yet to find a "true" non-NOA road where lane change works, there are plenty of such dual carriage ways near me, where none of them allow this feature.
Reactions: timpharrison
