Do you have to be on the FSD Beta or will the regular FSD Subscription work with Expanded Visualization? I do not see any buttons to expand the FSD Visualization on the regular FSD subscription.
It depends on what you mean by “expanded visualization.” If you’re talking about the display you’ve seen while drivers are using the FSD Beta, no, you don’t get that with regular FSD.
I'm referring to a wider visualization screen I have seen in some videos. The one I have is around 1/3 of the screen but I can't make that one bigger then what the default one is.
Well, if you have the "grab bar" (look for the thickened part of the vertical divider to the right of the visualization), then, yes, you can do just swipe it to right to make it larger. I was under the impression that this was only on the beta atm, but it's quite possible its also in the mainline build now as well (as per @DirtyT3sla).
