TL;DR: Disengaging FSD with steering input should enable TACC at the current set speed, not a new speed. This is dangerous and a very poor design.
I've noticed this behavior for a while with FSD, but it is clearly unsafe and I experience it in a new way last night.
When taking over from FSD by steering the wheel, you are put into TACC mode with no autosteer. The issue I'm showing in this video clip is that if you manually adjust the speed below what the engagement parameters are and then take over with steering, the TACC speed chosen is not your currently set speed. Instead, TACC chooses a new speed based on your speed offset settings.
For context, when you engage TACC, Autopilot, or FSD, you are allowed to set your speed parameter to be +/- a percent relative to the posted limit, or +/- a fixed value relative to the posted limit. My vehicle is set to +5 MPH over the detected limit.
Here you can see a video of me driving in a 35 MPH zone, I have manually lowered the FSD speed to 35, and when I steer the wheel you can see TACC is set at 40 MPH.
This is a pretty major problem when FSD is driving on an on-ramp or off-ramp, you take over steering because it's performing poorly, and it suddenly sets the TACC speed to 70 MPH when you're trying to round a corner. This is reproducible 100% of the time, in all conditions. The safety risks here should be pretty obvious to all, and IMO this is something Tesla absolutely needs to address.
