Full body PPF wrap and now left FWD won’t open
Discussion in 'Model X' started by onlinespending, May 19, 2018.
  1. onlinespending
    Portland, OR
    so I got a full body PPF wrap of my X recently and tried opening the FWDs one day later, to show to a friend, and the driver side FWD would not open. It made the warning beep without even trying to open. I had to manually override the entire opening, but was incredibly slow to open. Could the film somehow be interfering with the sensors? It’s just that one side that’s affected. Any other possibilities or things to try? I’ll certainly be calling both wrap shop and the Tesla service center on Monday
  2. outie
    outie Active Member
    SoCal
    Is it happening every time you try to open? Did it work ok when you first got the car back?
  3. onlinespending
    Portland, OR
    That was the first time I used the FWD after getting it back, which was just a day later. And yes.
  4. ZEPHYRHATS
    ZEPHYRHATS Member
    COLORADO
    I have heard you have to have an experienced wrapper that has done x's before or this WILL happen. I'm getting my car wrapped right when I pick it up and I had to research to find the best one who had done many Model X 'S.
  5. DaddyP713
    DaddyP713 Member
    Georgia, USA
    I haven't had this problem with mine, but I suppose it's possible. The ultrasonic sensors are said to be very sensitive.
    It may not be the wrap itself, but could be that the process of installing the wrap did something to the sensor - perhaps the sensor was marginally in spec from the factory, and putting pressure on the panel put it out of spec?
  6. Xminus6
    Xminus6 Member
    Bay Area, CA
    Was the car very hot on that side? If the door gets really hot it messes up the sensor and refuses to open. It’s lame but it’s happened to me a couple times.
  7. onlinespending
    Portland, OR
    Not at all. Was a mild, cloudy day. It started working again last night after a drive. So hopefully it’s rectified itself, but it’s certainly something I’ll have to pay attention to
