Funny smell in my Model S when AC is turn on
Don't know if this topic was address recently.
I usually do not turn the AC on unless its 79 degrees or higher. The weather has been really cool.
The other day was humid so I had the AC turn on. I noticed a funny smell coming out of the vent.
This happen again yesterday.
I had my car for almost a year now and so far everything has been working great.
Does anybody experience this at all?
Planning to call Service center to see what's going on.
I think that's just reality. Moisture builds up in the ducts and unless it's religiously dried out through frequent use, you get that sort of thing. Happens all cars as far as I know--particularly in more humid climates.
Auto parts stores make a spray that can help, at least for awhile. You turn on the fan full blast, then spray it into the intakes.
Agreed. Virtually every auto air conditioner in the world does that--especially when you first use it in the spring. Generally the cure is: Ensure the drain isn't plugged, change the cabin air filter, Use the anti-mould spray or liquid.
Eventually you may need to have the ducts cleaned. I've had to have this done on other cars. If you have really grimy road conditions, all kinds of weird gunk can build up in the ductwork, even on the far side of the air filter.
I don't know if Tesla Service offers duct cleaning as something they've trained their techs to do. But it's something they'll need to offer eventually
I had that on my GTI for about 3 years. I would blast full heat for about 3 days straight when I drove it (~3-4 hours of drive time) and it would go away for a while. I thought it was just my AC ductwork.
Then I finally changed my cabin air filter, and 90% of the smell was from that. I would recommend at least pulling your cabin air filter and checking it for odor, mildew.
mine stinks like mildew/mold wet everytime I run the AC. Never had a car with this problem.. ever. and it is really consistent with this car. Makes me wonder if that's why they added the ionizer in later versions.
Odd, doesn't happen at all with my non-ionizer car. Perhaps there is moisture build-up where there shouldn't be. Or my nose is failing me.
No smell in two plus years. As others have said, change the air filter (the new ones have carbon rather than just being paper). Also check that the drain isn't blocked--that's usually why the system stays damp.
I've had that smell once in a while in every car I've owned. A little trick I've found to get rid of it is to turn off AC towards the end of the trip (Or turn it off and put the vents on HIGH heat when parking ). That seems to clear out any condensation enough for the mildew not to take hold.
The Lysol solution should work. There are also commercial products available for this. Using the instructions for one of them, but with Lysol, might be a good idea. As many have pointed out, it's a very common problem. Nevertheless I never encountered it in decades of owning other vehicles until it happened to me, but not in the Tesla. Don't blame the specific car for what was in the air.
Aside from what people mentioned, a good way to avoid it is to leave the climate control on automatic. The car will use the AC to dehumidify when needed, and you won't be likely to use any significant amount of electricity in seasons where it's barely used. There are no fan belts and pulleys that affect the system so it's not a high overhead thing. Turning the AC on max every three months is also a good idea. It's something I mean to do, but never remember. Maybe I should add it to the car's maintenance minder in the "other" category right below tire rotations. Oh wait, the Tesla...never mind the last part. Put it on the calendar. That way it really will pop up on the console.
I have the same smelly problem with my Model S for two out of the three years I have owned it. Each time I take it to Tesla they change the air filter. Granted most of the smell disappears right after the change, but it comes back in 2-3 months. Now that the lease end period is nearing, I have a choice to make. I keep a musty smelling car that may have mold or I give it back and get another Model 3.
