Fuse Box in Refreshed Model S
RamshakleZ
83
59
Houston, TX, USA
I was trying to install a dash cam in my recently delivered refreshed Model S and it looks like they redesigned the fuse box (likely to accommodate the placement of the HEPA filter system). Unfortunately, the manual still has the old fuse layout in it so I'm not 100% sure what is what. I have to go into my SC tomorrow for something else anyway so I'll ask about this.
Needless to say... the Dash Cam didn't get installed today. :-\
zambono
1,160
606
DC
I see the positive terminal for the 12v, have you found out how to get to that if there is no power and the car is locked? As in how to open the frunk when the power is out.
RamshakleZ
83
59
Houston, TX, USA
Dropped my car off at the SC today (to fix an issue with my pano). They said they are aware that the manual has the old fuse box layout and Tesla will be sending out an updated version "soon."
RamshakleZ
83
59
Houston, TX, USA
Hasn't crossed my mind to check they yet (haven't even had the car for a week). But, that is a good point and is something I'll try to figure out when I get it back.
zambono
1,160
606
DC
Keep us posted, when I asked the guys at the store they had no clue.
MMinehan
101
33
Auckland, New Zealand
Can someone help me locate the cabin fuse box? The second one in the diagram supplied by obrien28? My power liftgate is not working. I can't call a ranger because I live in New Zealand (imported vehicle, Tesla is not here yet). And pictures on how to access it would be great. Thanks, Marty.
The A List
27
25
New Jersey
Does anyone know if you install a dash cam and connect it to the fuse box of that voids any part of the warranty?
The reason I ask is because I was at the dealership a few days ago and someone told me that if you mod the tesla logo on the back to the car, it will void your truck from warranty.
Lastly, do you need to connect the dash cam to the fuse box in order for the parking mode to work? That's the mode when the blackvue turns on via motion sensor. I was not sure what the official name is. :)
supratachophobia
3,849
2,675
Columbus, Ohio
View attachment 179069 View attachment 179071 View attachment 179070
What are you looking for, if I may ask?
SteveW25561
614
120
Vancouver, Canada
@RamshakleZ If you're installing a dashcam, the microphone area above the rearview mirror has an easily accessible, unused in North America, connector that is perfect for the always on dashcam install. I clipped this from a thread, and this user inserted pins into the connector -- I did something similar to tap into that for my Blackvue and it works perfectly. Sorry to the owner of this picture/post: I didn't note the URL I got it from, but it's on this site somewhere:
@obrien28 Thanks so much for the diagram! I've been looking all over for it, and the online, and in dash manuals don't have a fuse diagram.
In the linked file, it looks like the fuse box is flipped 180 degrees (or printed upside down). At least in my 2016 refresh S, fuse F100 is in the lower right corner as you stand in front of the car. Interestingly, F100 is also what controls the above mentioned microphone area unused connector.
In addition, the in-cabin fuse box you show seems to indicate it's on the passenger side (assuming North American layout with left hand drive). I thought the in-cabin fuse box is on the driver's side (thus left side in NA). Am I wrong?
FWIW I personally tapped into fuse F100 using an add-a fuse designed for Micro2 format fuses (available here: Amazon.com: Lumision FAST SHIPPING* ADD-A-CIRCUIT ATR MICRO2 FUSE-TAP Add ON DUAL CIRCUIT ADAPTER AUTO CAR TERMINAL + FUSE SET 5, 7.5, 10, 15, 20 AMPS: Electronics) -- this was to route an always-on 12V socket in my trunk so I could run a cooler if needed.
In order to snap back down the large cover over the fuse box, I did dremel out a small notch from the COVER (I took out a tiny 4 mm wide section of the lip on the cover that mates with the fusebox) so the cover could still snap on as the positive lead snuck out. I did not cut into or mod the fuse box -- I figured the fuse box cover is way way cheaper to replace if really needed.
Reactions: Xenoilphobe
seevT
84
58
SoCAL
hi guys,
can someone point to how to access the fuse box in AP 2.0 cars and which fuse is for the mic grill spare 12v supply. i am trying to replace the fuse for the spare 12v connector and getting no where..
on the verge of buying the blackvue system and getting it installed but the cost difference is 3x//:(
thanks..
Xenoilphobe
4,572
4,267
Fairfax County, Virginia
There is a fuse box on the drivers side kick panel (next the the accelerator pedal) - it has five fuses and one open slot in my 2014 P85+.
Follow this video and you will see it once you pull off the kick panel. (video starts a 2:00) once you pull those two trim pieces you will see a small 6 port fuse box with 5 blue 15 AMP mini/atm blade type fuses.
seevT
84
58
SoCAL
thanks. can someone confirm if the mic grill spare connector fuse is in the side kick panel? the posted video is from 2015 (before the front refresh)
