Hi, I own a 2016 MS 75D (refreshed) and the driver's side door handles (front and rear) as well as the driver's window control cluster all stopped working at the same time. The door handles still won't open the door if I slip something behind them to be able to pull them away from the car. The rear window control also does not work. Everything works as normal on the passenger side. I rebooted the car with no effect.
I'm guessing this is a fuse issue and am hoping to replace them myself, but would appreciate any insight's as to which fuse(s) specifically or whether it could be something else. The labeling in the posted fuse diagrams is a bit cryptic--F233 ("Door Controls and Front Handles: Left/Right"); F201 ("Window Motor, Left Rear"); F205 ("Window Motor, Left Front") seem the likely candidates, possibly only F233?
Any guidance/advice would be much appreciated!
