Fuse Rating of 12V Battery Positive Terminal (2016-2021 Facelift)
I noticed the positive terminal of the 12V battery in the Model S appears to have a fuse built into it. Does anyone know what the rating of this fuse is?
Well a year goes by and nobody knows? Both battery cables are black on my 2017 and the battery was missing. I accidentally put the battery in backwards and blew the fuse. It looks like a real easy fix once I know the value. I will just grab a larger fuse and solder the element in place. Anybody else have a comment on this?
The Module attached to the battery is the "SENSOR INTELLIGENT BATTERY". part number: 6007953. The parts list does not show a separate fuse so the entire module may need to be replaced. There is nothing in the schematic to show a separate fuse.
It is a 250a fuse on a 2016 model s.
The amperage imprint is on the metal spade under the bolt that holds it to the battery terminal part.
I had an imprint on the plastic ‘pa6t-g35’.
I eventually ordered it on Amazon
“Combo Pack!! NEW 82620-08040 8262008040 250 Amp Battery Fuselink Fuse w Terminal 90982-05054 for Sienna Mini Van https://a.co/d/i2CrInC
