FW 2019.28.2 charging issues
i have a 16 pre-facelift MS70 and just updated the FW a few hrs ago. Went to charge at a SC and it would randomly stop and go. Is anyone having the same issue. I already rebooted 3times (holding the 2 wheels and breaks and also 2 times from the main screen.
Installed 2019.28.2 yesterday, COMPLETE SYSTEMS MELTDOWN.
All AP systems failure
All Safety systems failure
Front motor failure
Re-gen not working
Charging was still working though
Car now with Tesla for a complete systems overhaul.
I had this happen at a SC last week and moved to another stall, where it charged fine. May not be your car...
I had the same problem on Tuesday. Kept stopping randomly. Unfortunately, the chargers were mostly full, so I put up with it only as long as I needed to. I will be traveling tomorrow and will probably be hitting a Supercharger on the way home, so we'll see what happens.
I have had intermittent charging problems that have occurred since installing 2019.28.2 - had to try multiple SC stalls (that I had used successfully before) after getting repeated "unable to charge" messages. Finally did a reboot and moved to yet another stall before I could charge. At my home charging station it's behaving oddly: I got a couple of brief "unable to charge" flashed but did not stop the charging process. Now it seems the car starts charging but quickly throttles down the rate to 1 Mile per hour -- then gradually over 5-10 minutes increases it up to the normal rate.
2016 MS90D EAP
