FW 8.1 AP2 no nags?
Discussion in 'Model S' started by trond.strom, Mar 30, 2017.
Tags:
  1. trond.strom
    trond.strom Member
    Norway
    looking at a couple of youtube videos of AP2 and it never nags. Is the nag really gone? is this AP2 HW only or will it be gone from my "old" AP1 car as well?
  2. Duke-U
    Duke-U Member
    Tilburg, Netherlands
    It's still there!
  3. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    It's there...I tested it several times. First nag seems to come in after 1:05, and it's just visual. Second is at 1:15: with an audible nag, and finally at 1:30 it cuts of you off for the rest of the drive. I don't find it an issue at all.
  4. Bryantclan
    Bryantclan Member
    Colorado
    I am 200 miles into a 700 mile road trip today on the new software... most of which so far has been on AP.
    Yes it nags you, but really not all that bad just have to give it a little nudge and it happily goes about its job.
  5. calisnow
    calisnow Active Member
    Los Angeles
    The nags suck. My prediction is they will remove nags from FSD and it will be a marketing gimmick to get you to cough up more dough.
  6. johnzhang22
    johnzhang22 Member
    Sunnyvale
    Yeah, it nags like every 2 minutes. Can't we just put a weight on the steering wheel?
  7. Robwoodruff
    Robwoodruff Member
    Ohio
    Just keep 2 fingers on the wheel. It's not really safe to drive yet without watching closely.
  8. bigdaddie
    bigdaddie Member
    Chowchilla, CA
    I also hate the nag. It wouldn't be so bad if it would give an audible warning BEFORE it cost you a "strike." I find myself looking at the speedo cluster too much to avoid the strike.
  9. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    It does give you several audible warnings? Are those not working for you?
  10. boonedocks
    boonedocks Active Member
    Gainesville, GA
    Many more and more often than I had on my AP1 car.
  11. oktane
    oktane Active Member
    Yes, but I wouldn't recommend it.
    • Funny x 2
  12. steveho
    steveho Member
    Minneapolis
    Until it turns, and pours that drink in your lap!
  13. JohnnyG
    JohnnyG Weee!
    Columbus, OH
    It gives you two audible warnings... The third audible is when it locks out AS for the rest of that drive.
    Right, wrong, or indifferent, I would like the option to choose from visual / audible / visual & audible. I would always have an audible tone. When I'm watching out the windshield, I don't always notice the subtle glow on the IC.
  14. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    Not sure I get what you're saying. If you're looking out the windshield...then you should hear the first audible alert. If you don't hear the first, you should hear the second. What extra are you looking for it to do?
  15. HumanGenome
    HumanGenome Member
    Sacramento, CA
    Yes but that is the least of things to worry about with the 8.1 update. Tesla team has some work to do!
  16. Ravenous21
    Ravenous21 Member
    San Diego
    What do you mean, what have you seen that's wrong with it?
  17. sdorn
    sdorn Director of Awesome
    Georgia
    I think he is saying that the very first alert is not audible at all, it is just the display flashing a white ring. It would be good if you could make that one audible as well.
    Personally I have only ever seen a nag like 3 times ever (but never got an audible warning as I grabbed the wheel based on the first visual nag), and each of those times I was purposefully trying to get it to nag me to see what it looked like and how long it would take to come on. It isn't really much of an issue to keep your hand on the wheel. It feels weird not to have it on the wheel.
  18. JohnnyG
    JohnnyG Weee!
    Columbus, OH
    Yes, I hear the audible alert, and I apply further pressure on the wheel so it knows my hand is still there, but when it gives you the audible alert, that is a strike against you. On the 3rd strike, you lose AP for the remainder of your trip. I can (and do) travel over 220 miles per stretch on pretty straight flat roads. It's fairly easy for it to miss your hand resting there if it's not moving the wheel a ton. I may miss the visual cue once every 50 miles or so, which then locks me out for the remainder 70 miles or so. I've mentioned before in other threads that I'm okay with the 3 strikes rule, but it should be something like 3 strikes within a 50 mile stretch or even a 100 mile stretch. That way if you miss the visual cue once every 25 miles or 50 miles or whatever, you can continue to use AP.
  19. dknisely
    dknisely Member
    Seattle, WA
    I tested the nag today (highway speeds; moderate traffic). The interval is much longer than previously, but it still nags eventually. Even the tiniest resistance on the steering wheel avoids the nag entirely. Just resting my hand on the wheel lightly is good enough. I hope the algorithm is a bit more subtle to require a genuine acknowledgement from the driver every now and then as a defense against falling asleep on long trips.
  20. HumanGenome
    HumanGenome Member
    Sacramento, CA
    It's basically like being in Mr. Toad's Wild ride. You know it's safe but it's a bit uncomfortable overall.
    That plus it hugs left and right in freeway corners or segments of freeway that have tight lanes or sharp turns. It's driven out of lane on 5-6 occasions.
    Both of those are expected and I've taken over when I see a sketchy bit of freeway but I can't help but try and see how it will perform. It's very impressive for a version 1 release. I expect many iterations of improved safety are going to quickly bring this up to AP1 parity!
