FW doors rubbing through paint
Discussion in 'Model X: Interior & Exterior' started by qadaemon, Feb 22, 2017.
  1. qadaemon
    qadaemon Member
    Sidney IL, Cape Canaveral FL
    Anyone else have bumpstops rubbing all the way through the paint on their FW doors? It looks like it's already damaging the metal underneath on mine as well. Going to see what the SC says next time they pick it up.
    Model X Falcon Wing door bumper damage
  2. jamtek
    jamtek Member
    Southern NH
    Yes, I am seeing something similar. I was thinking of putting little "circles" of Xpel film at these locations to protect the finish from further wear. The good news is that our Model X door frames are made of aluminum so we don't have to worry about rust starting here!
  3. outie
    outie Active Member
    SoCal
    I have the rubbed paint at a higher location, on both sides.
  4. qadaemon
    qadaemon Member
    Cool, makes me less worried that others are having the same. Still bothers me when I open the doors though :)
  5. choosetoshrug
    choosetoshrug Member
    Detroit
    #5 choosetoshrug, Jul 31, 2017
    I have the same issue and I find it unacceptable for a vehicle at this price point. They were supposed to send me some touch-up paint but never did.
  6. blake6551
    blake6551 Member
    Maryland
    I have it as well. I put xpel pieces on it, but it's slowly working its way through those as well.
  7. Freedom101
    Freedom101 Member
    Vancouver BC
    Are service centers not willing to fix this? This seems insane to me.
  8. outie
    outie Active Member
    SoCal
    They will most likely attempt to do something about it but repeated concerns will get them to tell you all their Xs on the lot have the same issue.
  9. choosetoshrug
    Detroit
    I already tried to get them to fix it. After sending it back three times they finally just threw their hands up, said they did all they could, and offered me the touch-up.
  10. EVTECH
    EVTECH Member
    Tesla is working on a permanent fix. They are redesigning the trim piece on the door that is causing the issue. Until then there is no need to get it fixed/repainted as it will come right back.
  11. rainforest
    rainforest Member
    Canada
    Oddly enough, I only have this issue on the passenger FWD. No issue on the driver's side.
  12. DarkMatter
    DarkMatter Member
    Olympia, WA
    The SC said today that they are still working on a fix for this. In the meantime I put paint protective film on both sides to cover the spot. So far the rubbed spot has only gone through the clear. If you catch it right away you might not even end up with that damage.
  13. sataponw
    sataponw Member
    Waterloo, Ontario
    I have a bit of a hard time picturing where the spot is on the car. Can someone please post a zoom-out picture and circle where the spot is. That would be greatly appreciated!
  14. Helmuth
    Helmuth Member
    Davenport, FL
    It’s just on one side also... nothing on the drivers side!
    • Helpful x 2
  15. MikeQ
    MikeQ Member
    The Real World
    I had my X completely wrapped with Suntek Ultra withing a couple weeks of delivery. I had two round pieces of film placed at the spots where I'd seen people complain about this. So far, no damage.
  16. EVTECH
    EVTECH Member
    Very well done. Mine is down to the primer/metal on both sides. I plan to get it corrected once there is an actual fix. Any day now. :-/
  17. MikeQ
    MikeQ Member
    The Real World
    Spot that gets damaged
    Suntek film applied
  18. DarkMatter
    DarkMatter Member
    Olympia, WA
    Also check the back of the door opening for rubbing. The gasket there can put scratches in the paint. I put a piece of film there as well until I get the service center to tweak the alignment.
