Fwd again
Discussion in 'Model X' started by Alpin, Aug 30, 2017.
Tags:
  1. Alpin
    Alpin Member
    Montreal
    After the last update, my FWD randomly misbehaves. SC checks the car log and said there is nothing wrong !
  2. outie
    outie Active Member
    SoCal
    What's the problem?
  3. Alpin
    Alpin Member
    Montreal
    It suppose to stop before hitting something !
  4. dragonxt
    dragonxt Active Member
    Bay Area
    It's possible there is nothing wrong.
    FWD is not 100% reliable.
  5. mal_tsla
    mal_tsla Member
    Austin, TX
    Is it set to "always open fully" at this location?
  6. outie
    outie Active Member
    SoCal
    Not really. There are dozens of scenarios where it would hit something.
    In your case the sensors would not have seen those lights.
    My FWD has scratches on it by hitting my garage door.
  7. vandacca
    vandacca ReActive Member
    Hamilton
    In my experience, the doors have been extremely cautious for the past 10 months. It does appear to have hit the lights, and I'm sure my door in the same situation would have stopped at least 1' before hitting those lights. I agree that it seems like it's ignoring the over-head sensors (something is wrong).
  8. Alpin
    Alpin Member
    Montreal
    same location, without moving the car, just different time, it can open just a little or completly and hits the light. I have my car since febuary and only since last week that the FWD misbehaves like that. Service center said there is no error in the logs.
  9. Alpin
    Alpin Member
    Montreal
    No
  10. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County Virginia
    Screw a Tennis ball to the ceiling and call it a day - resolved...
  11. Alpin
    Alpin Member
    Montreal
    Maybe directly on the door so it would work in any garage !
  12. Alpin
    Alpin Member
    Montreal
    I think the overhead ultrasonic sensor is wrong too but just because the logs said there is no error, the problem is not the car but the user ?
  13. outie
    outie Active Member
    SoCal
    With a ceiling that low I don't know why it would open that high. Did you close the door and re-open it immediately?
    Has it always been opening this high?
    I had experiences where if the door opened too low/little, I closed it and opened it up immediately again it would ignore the sensor and go wide open! Hence how I got my scratches.
  14. Tam
    Tam Active Member
    Visalia, CA
    It was not clear on the youtube whether any thing was hit.
    I assume that it did hit the ceiling light's net protector?
    If so, I think the sensor on top of your car's roof make a measurement up to the ceiling where the light is not there.
    I assume, in order for the sensor to work properly, it must be directly below the light so a correct measurement would be made.
    So the trick is to know where your top sensor is and make sure it measures a correct clearance as demonstrated by @Bjorn.
  15. outie
    outie Active Member
    SoCal
    Even if the sensor measures up to the ceiling where the light is missing, it should not have opened that high. That looks like a ~8ft ceiling (same as mine). If I don't set "Always open fully at this location" my doors open in umbrella mode. If I set it to "always open fully" it would only open up to about 80% or so, but never fully opened as shown unless overrode (which is actually possible to open fully with a 8ft ceiling), or bugged out like I described previously with a subsequent close/re-open.
  16. Bijli123
    Bijli123 Member
    Seattle, WA
    I faced the same issue yesterday night (after the software update). My FWD didn't detect anything. So obstacle markers at all. It bumped into the roof. And when I tried opening it standing close to the doors, they rubbed against me to open fully.
    Since today morning they have been working fine.
  17. systemcrashed
    systemcrashed Please Reboot
    Has the car been reset, or software updated since it was parked? Did you put the car in R or D without moving it?
  18. Tam
    Tam Active Member
    Visalia, CA
    The manual says:
    "...you must monitor the movement of falcon wing doors to ensure the door's path of movement is free of obstacles, staying prepared at all times to proactively intervene to stop the door from contacting an object..."
    It sounds like it shifts the responsibilty to owners which might explain Tesla's statement of "nothing wrong."
    • Disagree x 2
  19. Alpin
    Alpin Member
    Montreal
    It was working properly until the last firmware update. Maybe just an coincidence. Normally, it never open that hight, now it just swing full open and hit the light net. Yes, i can stop the opening manually but the video is for demonstration : why it happens now and not before, and not always ?
  20. Alpin
    Alpin Member
    Montreal
    And not only the fwd open fully but the trunk too. Much harder to prevent the trunk from hitting the ceiling.
