FWD door issue after 8.0 upgrade?
Discussion in 'Model X' started by passcore, Oct 8, 2016.
Tags:
  1. passcore
    passcore Member
    Marietta, GA
    I upgraded my 90D to the 8.0 software yesterday. While everything else looks fine, I seem to have developed an issue with the driver side FWD detecting a false obstacle while closing. I can always override and close. However I have NEVER had an issue with the FWDs until the Software upgrade. Anybody else having the same issue? Would recalibration help? I have never had any issues with the car over the 3k miles I have had it.. ☹️️
  2. Ryan MF
    Ryan MF Member
    New Jersey
    Also got 8.0 yesterday and noticed that the doors open faster but no issue with false obstacles. I've had this once in the past and it just went away on its own.
  3. outie
    outie Active Member
    SoCal
    No, I did not have the same issue. Only drove for a few miles after the update.
  4. jonman
    jonman Member
    MD
    have you tried the classic windows computer fix, reboot 3 times? lol.
  5. passcore
    passcore Member
    Marietta, GA
    Recalibration did not work.. I am gonna try the reboot. Ugh..
  6. mspisars
    mspisars Member
    Charlotte, NC
    I am curious if reboot works, I thought I saw an early report (non 8.0) of a sensor failing/failed and causing false obstacle alarms.
    On another question, in 8.0 if I override one FWDoor to open all the way in my garage, the message on the MCU screen shows as if both doors are set to open all the way. Does anyone know if the override is per side of the car or for both doors in one setting?
    The other side does have an obstacle and needs to stop lower...
  7. outie
    outie Active Member
    SoCal
    I do believe it's for both doors because the "always open fully at this location" button is on the top center, and when you press it both doors icon change to open fully.
    I have an annoying problem (not related to 8.0) is that my doors only open in umbrella mode when parked outside my garage since my garage is too low for fully open. I don't know why it still opens in umbrella mode when it's summoned outside. I don't want to press always open fully at this location because it will do that inside the garage (based on the door icons) and so I don't want to risk doors damage.
  8. passcore
    passcore Member
    Marietta, GA
    I believe that's because the location accuracy is probably about 10 or so meters so the car cannot distinguish whether it is inside or outside your garage.
  9. outie
    outie Active Member
    SoCal
    So it detects obstacles inside my garage and will continue to consider that irregardless there's no more obstacles outside? It's not like I performed any overrides based on location.
  10. passcore
    passcore Member
    Marietta, GA
    I believe so. I have the exact same behavior on my MX. I did however get the garage door raised so the FWDs can open fully.
  11. mspisars
    mspisars Member
    Charlotte, NC
    I did notice when it stops in umbrella mode, you can pull the open button one more time and it will open it all the way, that might be the way to overcome this without location specific "auto full open"..
    Seems silly that they would not make that a per-door option....
  12. mspisars
    mspisars Member
    Charlotte, NC
    Disclaimer: try this at your own risk...
    @outie and @passcore I just went and tested my X FWDoors.
    I overrode the passenger FWDoor, and set it to remember.
    Then I went to the driver side FWDoor and opened it from the outside, it opened in umbrella mode.
    I closed and opened the driver side FWDoor from the MCU and it went higher, but still stopped short of the garage door opener (which if I could just move another 4+ inches back, this whole thing would not be an issue for me at all).
    The passenger side FWDoor still opened all the way.
    Now, I am not sure if this is a fluke, or if it is in fact setting the override on a per door basis.
    Either way, with the override (open to full) set for my location, the door still seems to "respect" obstacles in my small test case.
  13. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    Mine behave exactly the same way. I guess its just the comfort zone for Tesla on geolocation.
  14. outie
    outie Active Member
    SoCal
    So if you set to always fully open at this location, it will still (supposedly) stop if it detects obstacles? I might have to give that a shot.
  15. Saghost
    Saghost Well-Known Member
    Delaware
    That's my understanding as well.
  16. FarmerDave
    FarmerDave Supporting Member
    Martinsburg, PA
    I had the same problem this am after updating to V8 last night. A false obstacle detection on the driver side FWD when almost closed. No one and nothing in the second row. I never had this issue before in over 12K miles. I also did an override to close.
    The door worked OK when I got home, so will watch and wait.
  17. passcore
    passcore Member
    Marietta, GA
    Even in my case the door closes without the obstruction issue about 3/10 times. Reboot or recalibration did not work so I am probably going to get an SC appointment. I do have a few minor trim related stuff to fix so hopefully I can get all that done in one visit.
  18. FarmerDave
    Martinsburg, PA
    Version 8 seems to have removed some successful Model X door fixes that were implemented in 7.1. Since my last post the phantom obstacle on the driver side FWD has occurred twice. Tonight as I was getting in the car the driver's door closed on my left foot without warning. I now have a sore black & blue foot and am more than a little pissed.
    Is it possible to revert to version 7.1?
  19. aesculus
    Northern California
    There has been talk of this over in the S forums but so far nobody has come up with a way and one person asked at a service center and they said no. But that was not the official stance. You could send a note to [email protected]
  20. FarmerDave
    Martinsburg, PA
    Done. I'll post any response I get.
