FWD sensor thinks there is an obstacle (when parked I the sun)
Hi,
So I have a 2017 model X. And whenever the passage sur side FWD is hot (usually parked in the sun), the sensor shows that there is a obstacle that prevents the door from opening (I can see the red bar on the mcu screen) and, well doesn’t open fully ( as it should if there was an obstacle).
I suspect the sensor is has moved or is on the Fritz. Anyone has experience with this ? I’ll ask Tesla, but I’d rather have an educated opinion first.
Thanks
Hi @Marcboy ,
Many here have experienced your problem. (Not me)
Some had the problem to different degrees dependent
upon the color of the car.
The final resolution was some sort of "butyl patch"
to attach the sensor.
The problem was solved...
Good luck,
Shawn
