Galaxy S6 not playing working with bluetooth
Discussion in 'Model S: User Interface' started by zax123, May 5, 2015.
  1. zax123
    zax123 CDN Model S 100D
    Candiac, QC, CAN
    Hi all,
    I recently upgraded to a Galaxy S6. I'm having a lot of problems with bluetooth in my S. Sometimes it connects to bluetooth, but most often it does not. I can sometimes get it to connect manually by clicking the "Connect" button, but that usually just puts the bluetooth system in a loop and nothing ever happens. Rebooting the center console usually fixes it, but the next time I get in the car my phone doesn't connect to the car.
    My phone is with Bell in Canada.
    I was wondering if anyone else is experiencing bluetooth problems with their S6. I'd be glad to hear from people who are using it without a problem. Maybe I have a hardware issue and I can get it exchanged.
    Thanks!
    Rob
  2. jhs_7645
    jhs_7645 VIN: #3305
    Camas, WA
    I have an iPhone, but as a general rule for disconnect/reconnect issues, you can check the following:
    1) delete your phone from the Tesla
    2) delete the Tesla from your phone
    3) re-pair them
    If that doesn’t work, sometimes your phone bluetooth can be trying to talk to other LE devices? I’ve got a few ‘tiles’ and whenever my phone wants to talk to them it can sometimes cause dropout issues with the bluetooth audio that is currently running.
  3. zax123
    Candiac, QC, CAN
    Thanks @jhs,
    I actually did redo the pairing process and no dice. Argh. I'll try again though when I'm next in the car.
    Why is bluetooth so flaky after so many years? :)
  4. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Hi Zax,
    My new S6 is working perfectly with Bluetooth in my Model S.
    I will note that this is my second S6. The first had an intermittent problem with its speaker. Definitely was a hardware problem. I swapped it at the store for a new one and it's been perfect. I wouldn't rule out a hardware problem in your case.
  5. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    Add to that Google has really screwed up Bluetooth in 5.1 ....
  6. EarlyAdopter
    Redmond, WA
    Good news! The S6 is still on 5.0.2. ;-)
  7. Speedbird
    Speedbird Member
    Houston
    S6 works fine for me so far. No issues with any sync or audio.
  8. zax123
    Candiac, QC, CAN
    Hi all, thanks for the replies! I know it likely makes NO difference as the hardware is probably identical, but do you guys have the S6 or S6 Edge? I have the S6. I doubt they changed the bluetooth chip, but I just want to make sure before I make a fuss at the phone place to get it changed. :)
    Thanks!
    Rob
  9. Speedbird
    Speedbird Member
    Houston
    Edge here.
